WAS top / Saratoga top care and maintence, A how to keep it nice / restore thread |
Mikey914 |
Aug 24 2011, 01:02 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Just thought I'd put a "how to" Thread together. Yes Acrylic will scratch, the good news is it can be restored. In fact I'm even thinking about making a restore "kit" that would include smaller sizs of the compounds that I use, as they come in 48oz bottles. Anyway, I started with a piece of rejected acrylic and made a "Test" pattern to sow you what was possible. |
Mikey914 |
Aug 24 2011, 01:09 AM
I start by wetsanding with 1200 grit.
Attached image(s) |
Mikey914 |
Aug 24 2011, 01:10 AM
Wipe clean and repeat with 2000 and 3000.
Attached image(s) |
Mikey914 |
Aug 24 2011, 01:15 AM
Start by useing a mild cutting compound to reduce some of the fine scratches caused by sanding.
Mikey914 |
Aug 24 2011, 01:23 AM
Wipe clean and follow up with a machine polishing compound, and following up with a superfine polish.
For a total of 3 steps. You will need to switch to sponge pads for steps 2 and 3. Attached image(s) |
Mikey914 |
Aug 24 2011, 01:26 AM
Repaired test section
Attached image(s) |
Mikey914 |
Aug 24 2011, 01:27 AM
Side view
Attached image(s) |
Mikey914 |
Aug 24 2011, 01:28 AM
Decided I'd try to clean up my scratched Saratoga top
Before Attached image(s) |
Mikey914 |
Aug 24 2011, 01:32 AM
Wetsand with 1200, 2000, 3000
Attached image(s) |
Mikey914 |
Aug 24 2011, 01:35 AM
I polished as I did before, unfortunately when you repair scratches you find more. You will notice that as you sand you can see the scratch until it's sanded out. You need to get these all the way out with 1200, before moving on to the next 2 steps
Attached image(s) |
Mikey914 |
Aug 24 2011, 01:40 AM
You can really make these look good, I typically spend 2-1/2 hours on a roof prepping before I ship.
The one this to remember is as you polish you will build up a static charge. If you use a Meguires #1 plastic cleaner last, it will discharge the plastic so that every piece of dust that exists to your now clean top. Attached image(s) |
Drums66 |
Aug 24 2011, 04:49 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.......BFH (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/poke.gif)
(IMG:style_emoticons/default/bye1.gif) |
StratPlayer |
Aug 24 2011, 04:51 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Amazing
Drums66 |
Aug 24 2011, 05:23 PM
Amazing ......But seriously.......what you've done there is *Amazing* (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 5th June 2024 - 01:38 AM |
