Cable Shifter, Anyone know these? |
Jeroen |
Apr 24 2003, 06:51 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Has anyone have any experience with these guys?
Brandwood cable shifter for the 914 I found them through a 550spyder board and they were pretty pleased with it... cheers, Jeroen |
Brad Roberts |
Apr 24 2003, 11:25 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
He is the guy who makes all the cable shifters for ALL of the vendors (Patrick/Renegade) He doesnt really say it.. but he started with mid-engine sand rails. I'm sure they work.. just doesnt give you the feel of a solid linkage shifter.
Nice find. I keep forgetting his name. I knew he was in AZ near Patrick. B |
Jeroen |
Apr 24 2003, 01:59 PM
Ok, you help me out here a bit...
I'm trying to decide between a cable shifter setup or a Wevo shifter I know I like the feel of the Wevo shifter, but I have a /4 tailshifter The reason why I'm looking at a cable shifter, is because I don't like the position of the stock shifter (and with a cable shifter, I can pretty much put it where I want). On the other thread, you mentioned a tailshifter would do just fine, but I think you were talking about a /6 tailshifter which has different (better?) linkage than the /4 tailshifter... Any words of wisdom? cheers, Jeroen |
Aaron Cox |
Apr 24 2003, 03:01 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
I've seem his stuff advertised by veedubber vendors. i think for sandrails and vw engines. Interesting product.
Im still confused on the concept though, i understand that: when you go for 1st, 3rd, or fifth you would pull the cable toward the front of the car. and the other cable would do left to right motion. how do you go for rev, 2nd, or 4th. You cant "push" a cable baack into its sleeve - its not rigid enough- it would bend (IMG:style_emoticons/default/huh.gif) im lost? (IMG:style_emoticons/default/huh.gif) |
JWest |
Apr 24 2003, 03:05 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Actually, the cables used are pretty stiff, and they have sleeves on the ends so they do work when pushed.
Lo-Fi Version | Time is now: 12th June 2024 - 05:11 AM |
