75 914 1.8 FI won't start |
PBC914 |
Aug 27 2011, 09:39 PM
Member Group: Members Posts: 192 Joined: 30-December 10 From: Minneapolis Member No.: 12,545 Region Association: Upper MidWest |
I have a 75 1.8 with FI that won't start. This problem started after I took it for a long run yesterday and the engine got pretty hot (almost in red) on the temp gauge. Not sure if that is part of it.
When I turn the key to "on" I don't hear the fuel pump run. But, when I try to turn it over, I can hear the fuel pump running/I know the pump is getting electricity. Does the fuel pump need to run initially before startup? I swear I have always heard it before starting the car. Any ideas? |
dlee6204 |
Aug 27 2011, 10:37 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
QUOTE Does the fuel pump need to run initially before startup? I swear I have always heard it before starting the car. No, with L-Jet, the fuel pump only runs when cranking or when the flap inside the air meter is open (i.e. running). With D-Jet systems, the fuel pump runs for 2-3 when the key is turned to on. Does it attempt to start at all? |
PBC914 |
Aug 27 2011, 10:44 PM
It will turn over, and if I turn it over long enough after many tries it will begin to start, and then I need to stay on the gas for awhile to keep it from stalling. If I drive it for a few minutes it remains running then.
914Mels |
Aug 28 2011, 01:11 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Does the engine seem to crank over faster than it did before? If you got it hot, the valves may have tightened up and now your compression will be down somewhat and make it hard to start. How's the power level once you get it running?
Valy |
Aug 28 2011, 01:49 PM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Seems your AAR is close.
Take out the vacuum hose between the AAR and the Y splitter close to the air box. Plug the Y and check that you have vacuum through the AAR. If not, it doesn't work. |
Lo-Fi Version | Time is now: 29th May 2024 - 04:35 AM |
