How to mount 4 point harnesses, Have GTS Seats |
casey944 |
Aug 28 2011, 06:55 PM
Member Group: Members Posts: 139 Joined: 10-August 09 From: nova Member No.: 10,654 Region Association: MidAtlantic Region |
Purchased these wonderful seats
(IMG:http://www.914world.com/bbs2/uploads_offsite/tpcracing.net-10654-1314579319.1.jpg) and now that I am really getting the car sorted I would like to be safer... Is there an options for a harness bar that mounts behind the seats to mount a set of 4 point harnesses? Don't really want to run a sub belt for street driving although the seats have a spot for them... I honestly wouldn't mind something that also went across the door down towards the front of the floor if it all was integrated and worked well.. Any help? Would be great if i didn't lose any of the seat travel as I am a tall guy. Thanks in advance! |
Vysoc |
Aug 28 2011, 07:46 PM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Casey,
Stable Energies has a Harness Bar that works in a 914 you have to do a little navigating on their Web Site but there is one in there. Vysoc (IMG:style_emoticons/default/flag.gif) |
EdwardBlume |
Aug 28 2011, 08:40 PM
You can install eye bolts behind the seats and thread them through the back pad. Use big washers on the engine side to keep you strapped in during a collision. (IMG:style_emoticons/default/first.gif)
nsr-jamie |
Aug 29 2011, 05:31 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
How about this place Rennenmetal? They have excellent prices and better than the Weltmeister piece
Here is the link and looks to be on sale too right now as well http://www.rennenmetal.com/proddetail.asp?prod=1800 Cheers Jamie |
nsr-jamie |
Aug 29 2011, 05:49 AM
Forgot to write, but would you happen to have some pictures of these GTS seats installed in your 914? I am thinking about getting the same seats as well....Can I ask where did you buy them?
casey944 |
Aug 29 2011, 06:27 AM
Forgot to write, but would you happen to have some pictures of these GTS seats installed in your 914? I am thinking about getting the same seats as well....Can I ask where did you buy them? Not the best photo but the only one I have of them installed: If I were to do it again I would have gotten a more supportive seat than the Lemans for the drivers side. Bought them directly from Stefan @ GTS Classics |
Dave_Darling |
Aug 29 2011, 10:02 AM
The routing of the lap belts would worry me. If they sit right on the bolster, they aren't snug around your hips which is where they should be. The shoulder belts I am less concerned about; I know that in my case my shoulders are above the wider part of the seat anyway.
The primary function of the sub strap (single or dual) is to keep the lap belts located low on your hips, which is where they belong. Too easy to pull them upwards with the shoulder straps. This is one big reason why four-point belts are almost never recommended by anyone for actual safety. (You'd fail tech with them for DE's locally; your stock three-point belts would pass.) For the street, three-points are preferred. If the four- (or more-) point belts are as tight as they should be for safety, you cannot turn around to look behind you. Makes backing up a lot harder, and more dangerous. You will also not be able to reach some controls, like the radio. (Yeah, I know--but I do listen to the radio in my 914!) Again, not so good for a street car. Stick with the three-points for the street. For the track, go with a five-point setup. Check the manufacturer's recommendations about mounting for those, and check with the local safety folks about installation. Some outfits will not allow the belts to be anchored to a harness bar, so you would need eyebolts (or bolts) through the firewall to actually be the anchors. And you might have to cut away the back-pad so the contact is metal-to-metal, as some sanctioning bodies insist on that as well. --DD |
eric9144 |
Aug 29 2011, 10:20 AM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
I'm with Dave on this one, 3 point or 5/6 point belts are going to be safer than 4 point... And as Dave also stated, most safety reg's will not even allow 4 point belts. If you're going to do it, add sub straps and go 5 point... |
carr914 |
Aug 29 2011, 10:55 AM
Racer from Birth Group: Members Posts: 118,949 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I both Agree & Disagree with Dave's assessment
The waist Belt needs to be in proper alignment, BUT I have seen a lot of Shoulder Belts installed improperly and those seats do not have an Alignment slot like a racing seat has. Therefore the Belt could easily slip out of where you want it. Also misinstalled Shoulder Belts can lead to Compression Fractures in your back in a crash. Sub Straps are there to prevent you from Submarining forward under the waist belt in a hard collision, not for proper alignment of your waist belt, even though it is often used that way |
Lo-Fi Version | Time is now: 4th June 2024 - 03:00 PM |
