Need 911 Front Torsion Bars, In 22mm |
jmill |
Aug 28 2011, 08:51 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Where can I get a decent price and not wait 3 weeks for them?
EdwardBlume |
Aug 28 2011, 09:03 PM
Try your luck with a want ad. Or you could call GPR...
Eric_Shea |
Aug 28 2011, 10:10 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Are you racing this car?
markb |
Aug 28 2011, 10:13 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Have you called us to see what we have on the shelf?
pcar916 |
Aug 29 2011, 03:03 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Rich Bontempi at High Performance House (Redwood City, CA) may have some as well.
J P Stein |
Aug 29 2011, 06:03 AM
22mm front T-bars are mighty stiff for a 914...unless you're going racing.
jmill |
Aug 29 2011, 09:12 AM
Are you racing this car? Yup. It'll see some street time but I'm building a road race car with minimal to no street comforts. I have 225# rear springs and will be in the market for a 23mm bar when funds allow. Have you called us to see what we have on the shelf? Nope. I will today. |
J P Stein |
Aug 29 2011, 09:56 AM
For a data point:
My 21mm T-bars were balanced by 275 lb rear springs, 22mm (effective) AR bar set half hard. No concessions to streetability. |
jmill |
Aug 29 2011, 04:28 PM
For a data point: My 21mm T-bars were balanced by 275 lb rear springs, 22mm (effective) AR bar set half hard. No concessions to streetability. (IMG:style_emoticons/default/idea.gif) AX or Road Course? |
pcar916 |
Aug 29 2011, 04:49 PM
Mine's a track car in the same ilk.
Front 23mm torsion bars 22mm Tarrett bar Bilstein sport inserts in Bilstein struts Rear 200# springs yellow adj Koni's no AR bar Elephant poly-bronze in the back and about to be in the front when I get a day free to install them. Now that I built the last tranaxle with a clutch-type LSD I'll have to add a rear AR bar or "up" the rear springs to fight a wee bit of understeer. I don't care if it's a bit stiff... so am I. I use it almost daily as well and damn the tire wear. We have a lot of real twisties in Arkansas. (IMG:style_emoticons/default/beerchug.gif) |
J P Stein |
Aug 29 2011, 05:59 PM
For a data point: My 21mm T-bars were balanced by 275 lb rear springs, 22mm (effective) AR bar set half hard. No concessions to streetability. (IMG:style_emoticons/default/idea.gif) AX or Road Course? AX. My front end weighed in at about 700 lbs, about 1000 in back. I've driven a 914 track race car on an AX course. He could get away with stiff suspenders on a billard smooth track but was undriveable at speed out in the parking lot. IIRC his rear springs were in the 600 lb range on a 1900 lb car. |
Jeffs9146 |
Aug 29 2011, 07:30 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I have a set of torsion bars that I got from an 82 sc but I couldn't find any markings to indicate what they are!
If you know how to tell what they are I will take a closer look for you! $40 plus shipping. |
jmill |
Aug 29 2011, 08:51 PM
They'll most likely be 18.8mm. Just measure the outside diameter (not at the splines). I have a set of them I got with the 911 front end.
I emailed GPR. None on the shelf. They'll let me know tomorrow if their supplier has them. |
Jeffs9146 |
Aug 29 2011, 11:25 PM
I will check them tomorrow and let you know the outside mesurment!
Jeffs9146 |
Aug 30 2011, 04:23 PM
Sorry, mine are 19mm! (IMG:style_emoticons/default/sad.gif)
vtursi60 |
Aug 30 2011, 05:31 PM
Newbie Group: Members Posts: 11 Joined: 11-February 11 From: Florida Member No.: 12,696 Region Association: None |
I have set of 23 mm torsion bars 911 .
jcd914 |
Aug 30 2011, 06:51 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I know some here warn about too stiff but not all of us.
Set mine up 20 yrs ago and I loved it. 911 T frt struts & brakes Polygraphite suspension bushings fr & rr (hard ones) 22mm front T-bars (914) 180 lb rear springs (cut and shortened) 19mm front anti roll bar (heim jointed drop links) Koni yellow sport gas shocks frt & rr. Daily driver, auto-x and occasional road trip. Very balanced car. Was always near the top of my auto-x class (not saying much since it was a 1.7L) Jim |
Jeff Hail |
Aug 30 2011, 06:54 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Sway Away solid 22mm bars PN# SAW1822 for 74-89 911 Turbo.
Never used, brand new. $225 includes shipping. PM me if interested. Jeff |
jmill |
Aug 30 2011, 07:06 PM
PM sent. Turbo has the same arm and spline count?
Lo-Fi Version | Time is now: 4th June 2024 - 05:59 AM |
