Small master cylinder leak, Where lines come in front above |
PanelBilly |
Sep 2 2011, 07:36 PM
914 Guru Group: Members Posts: 5,814 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Small amount of fluid coming from rubber plugs that connect the line to the mc. System has been dry for awhile. I thought it was coming from the copper washers but I replaced them and it's still forming drops
PanelBilly |
Sep 3 2011, 08:37 AM
Itg looks like I need to replace the rubber stopper where the tube comes in from the reserve. Anybody have any hints at the simplest way to do this?
swl |
Sep 3 2011, 01:06 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Doing that now - actually replacing the MC. There is NO easy way. Those puppies are the worst part of the MC swap. Best advice I got from previous threads was to disconnect the reservoir so you can pull the MC down where you can get at the top of it.
Pelican parts tech write up - http://www.pelicanparts.com/techarticles/9...er_cylinder.htm |
sean_v8_914 |
Sep 3 2011, 01:15 PM
its like trying to explain alligator wrestling...
Black22 |
Sep 3 2011, 04:39 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Best advice I got from previous threads was to disconnect the reservoir so you can pull the MC down where you can get at the top of it. (IMG:style_emoticons/default/agree.gif) I just removed the reservoir bracket and lowered the whole thing so I could get my hands on the top of the MC. |
Lo-Fi Version | Time is now: 5th June 2024 - 08:42 AM |
