Radio Power |
Radio Power |
andys |
Sep 3 2011, 12:12 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
I'm installing a Sony radio that needs switched and constant 12+. What are the best sources for radio power? My steering column is removed, so I can't check 12+ at the moment. Is cig lighter constant or switched (I'd like to tap off of that since I never use it anyway)?
Thanks, Andy |
windforfun |
Sep 3 2011, 12:25 PM
Senior Member Group: Members Posts: 1,809 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
For a "73 1.7, the cig lighter is switched.
76-914 |
Sep 3 2011, 01:06 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Do it at the fuse panel. There is no reason not to on this car. It's super easy. Disconnect - at bat, remove the 2 screws holding the fuse block up and you'll find what your looking for. There might exist a double spade on 10 or 11. I can't remember which one it is but both of my 914's had this extra available spade. No matter; you can slip 1 or 2 doublers on at the fuse block. You won't have to cut or splice any factory wiring this way. And again, it's super easy.
andys |
Sep 3 2011, 02:59 PM
Do it at the fuse panel. There is no reason not to on this car. It's super easy. Disconnect - at bat, remove the 2 screws holding the fuse block up and you'll find what your looking for. There might exist a double spade on 10 or 11. I can't remember which one it is but both of my 914's had this extra available spade. No matter; you can slip 1 or 2 doublers on at the fuse block. You won't have to cut or splice any factory wiring this way. And again, it's super easy. I need both a switched and a constant 12+, so I need to know the function of 10 or 11. As I mentioned earlier, I can't check anything with the DVM with no power at the moment. Thanks, Andys |
jcd914 |
Sep 3 2011, 03:21 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Do it at the fuse panel. There is no reason not to on this car. It's super easy. Disconnect - at bat, remove the 2 screws holding the fuse block up and you'll find what your looking for. There might exist a double spade on 10 or 11. I can't remember which one it is but both of my 914's had this extra available spade. No matter; you can slip 1 or 2 doublers on at the fuse block. You won't have to cut or splice any factory wiring this way. And again, it's super easy. I need both a switched and a constant 12+, so I need to know the function of 10 or 11. As I mentioned earlier, I can't check anything with the DVM with no power at the moment. Thanks, Andys From 74 wiring diagram: Fuse 8 Power with key on, no power while cranking (X circuit - accessories) Fuse 9 Power key on and cranking (T15 circuit - ignition) Fuses 10, 11, 12 Battery power (hot all the time) Jim |
Lo-Fi Version | Time is now: 29th May 2024 - 02:30 AM |
