Porsche Cup II wheels, 17 inch |
r_towle |
Sep 5 2011, 10:54 AM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I am told that Porsche Cup II wheels will bolt right onto an 84 911 carerra, all fine with no rubbing.
OK, that makes sense, the offset seems close enough. Do these same wheels fit on a 914 and does anyone have pics? I figure I cant drive both cars at the same time...so why not have some swappable rubber and wheels. I have 15's in the 914, 16's on the 911 and I believe 17's will look nice on both. 17's have more rubber available and the type of tire I am seeking is not race rubber but all weather/winter rubber. Rich |
sixnotfour |
Sep 5 2011, 03:00 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
You will need spacers for the 911 and 914
914junkie |
Sep 5 2011, 09:15 PM
Member Group: Members Posts: 167 Joined: 14-December 08 Member No.: 9,848 Region Association: None |
You will need spacers for the 911 and 914 (IMG:style_emoticons/default/agree.gif) You would need 1" spacers on the Carrera and possibly more than 1" on a GT flared car I would think, depending on how close you want to run them to the lip. I ran Cup II's on my Sheridan body car for a bit. Not GT flares but might give you an idea of what it would look like. ~ Paul |
zambezi |
Sep 5 2011, 09:27 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Not Cup II's but similar wheels are the turbo twists. I have 7's on all 4 corners with no flares just standard rolling of the fender lip. I have 3/8 spacers on the rear and either 1 inch or 3/4 up front (don't remember right now).
r_towle |
Sep 5 2011, 09:31 PM
what year are those wheels from?
And, what size tire are you running? I am looking to do the same thing...no flares on either car. Rich |
IronHillRestorations |
Sep 5 2011, 10:14 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
IIRC the Cup II wheels are 964 series, which would make them have the later offset, so you'll need spacers
Cairo94507 |
Sep 6 2011, 06:42 AM
Michael Group: Members Posts: 9,796 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Zambezi- That is looking very nice.
BajaXJ92 |
Sep 6 2011, 07:39 AM
Extended Member Group: Members Posts: 2,146 Joined: 20-April 06 From: Prescott, AZ Member No.: 5,895 Region Association: MidAtlantic Region |
Not Cup II's but similar wheels are the turbo twists. I have 7's on all 4 corners with no flares just standard rolling of the fender lip. I have 3/8 spacers on the rear and either 1 inch or 3/4 up front (don't remember right now). Would love more details on those wheels, tire size, and your setup. How far did you actually have to pull the fender lips out? Did you roll them on the tires with a baseball bat? The car looks great! |
zambezi |
Sep 6 2011, 09:41 PM
here is some more info on my set up. I am running stock brakes and suspension with redrilled rotors and screw in studs (loctite of course). The rear wheels have 1/2 inch spacers (I measured everything tonight). The fronts are 1 inch spacers machined down to the minimum I can go before I will have interference problems with the strut. The finished machine thickness came to .830 inch. The hub-centric portion needed to me remachined in the back side of the spacer anyways due tho the early style hubcentric design (much larger than the current design used by Porsche). The wheels are all 7" wide with a 55 mm offset. This is the standard wheels used on the fronts of any early year boxster or even the 911's if they had the 17's. They are commonly called "turbo twists". I have another full set in my shop of 7's and 8.5's. I also am running them on my 928 but they are the 911 sizes of 7's and 9's. The 914 is running 205/50/zr17's on all 4 corners. The fenders on the 914 are stock except the lips have been rolled. And by rolled I mean with the use of a hammer and dolly they have been turned up flat against itself rather than the factory 90 degree ledge. I did not use a bat or similar method at all to push the fender further out. I also have raised the front end slightly from the first pics. I am including a current picture I took tonight of the stance. Hope this all helps.
JIM front wheel spacer rear wheel spacer wheel designation markings front wheel-well lip rear wheel-well lip current stance - motor is in but no deck lids |
Lo-Fi Version | Time is now: 28th May 2024 - 11:25 PM |
