> 915 Gearing chart, Gearing chart spreadsheet
RON S.
post Jul 19 2004, 10:01 AM
9140430841, FINALLY RUNNING
I found this .xls spreadsheet while surfing the web last week.
I'll try to attach it but if it doesn't work,you can go to Instant-G's website and down load a copy for yourself.
In a nut shell,you plug in your gear ratios,tire dia's,& axle ratios,and in each gear 1-thru-5, it'll calculate RPM's,top speeds at each shift.Pretty cool.It'll work with 901 boxes to.
Ron
Attached File(s)
Replies(1 - 1)
Britain Smith
post Jul 19 2004, 10:32 AM
Nano Member
I have a file for both the 901 and 915 tranny with all the gears available that I know off...try these. Let me know if you need some help using it...I added to comments to the areas that need to be filled in by the used.
-Britain
901 Tranny Calculations
915 Tranny Calculations
- Lo-Fi Version Time is now: 7th June 2024 - 08:47 AM
