I found this .xls spreadsheet while surfing the web last week.
I'll try to attach it but if it doesn't work,you can go to Instant-G's website and down load a copy for yourself.
In a nut shell,you plug in your gear ratios,tire dia's,& axle ratios,and in each gear 1-thru-5, it'll calculate RPM's,top speeds at each shift.Pretty cool.It'll work with 901 boxes to.
Ron
