915 Gearing chart, Gearing chart spreadsheet |
RON S. |
Jul 19 2004, 10:01 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I found this .xls spreadsheet while surfing the web last week.
I'll try to attach it but if it doesn't work,you can go to Instant-G's website and down load a copy for yourself. In a nut shell,you plug in your gear ratios,tire dia's,& axle ratios,and in each gear 1-thru-5, it'll calculate RPM's,top speeds at each shift.Pretty cool.It'll work with 901 boxes to. Ron Attached File(s) 915GEARCHART.xls ( 220.5k ) Number of downloads: 156 |
Britain Smith |
Jul 19 2004, 10:32 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I have a file for both the 901 and 915 tranny with all the gears available that I know off...try these. Let me know if you need some help using it...I added to comments to the areas that need to be filled in by the used.
-Britain 901 Tranny Calculations 915 Tranny Calculations |
Lo-Fi Version | Time is now: 17th May 2024 - 10:33 AM |
