Higher volume oil pump, Did i mess up?? |
jporsche914 |
Jul 19 2004, 03:02 PM
Member Group: Members Posts: 149 Joined: 9-March 04 From: colorado, springs Member No.: 1,769 |
I am getting my 1972 1.7L rebuilt back to stock except for the 40% more volume oil pump. The reason i am getting it rebuilt is because one of my bearing went out so i thought more oil would be better than stock. Did i make the right choice picking more volume and a little more presure or will it just give me problems? Is 40% overkill??
Thanks |
Jake Raby |
Jul 19 2004, 03:23 PM
More volume is better, but what pump did you choose?? The easy way out is the Melling cast iron pump, but they have leakage (internal and external) problems..
Retrofitting a Type I pump is the best way to do it! |
jporsche914 |
Jul 19 2004, 03:29 PM
I ordered the Heavy duty oil pump from the perfomance products website. I am not sure who makes the pump.
Jake Raby |
Jul 19 2004, 03:37 PM
It has to be Melling, its the only one thats a drop in.
jporsche914 |
Jul 19 2004, 03:42 PM
What should i do?? Should i have them pull the motor and get a rebuilt original pump put on?? Or will this be ok??
rick 918-S |
Jul 19 2004, 04:07 PM
Hey nice rack! -Celette Group: Members Posts: 20,474 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I'm always concerned about the oil pump when a motor spins a bearing. Could be the cause of the failure. I would do what ever Jake say's.
jporsche914 |
Jul 19 2004, 04:33 PM
So Jake what should i do.
Thanks |
Jake Raby |
Jul 19 2004, 05:12 PM
What cam are you using?? This makes a big difference in what can be done, as the gear needs modification.
jporsche914 |
Jul 19 2004, 05:16 PM
I am using a stock cam but the bearings on the cam where bad and they have not determined if the cam is still good. So do i have to get a different cam??
Jake Raby |
Jul 19 2004, 05:53 PM
The gear is the main thing for the oil pump install.. Trash that stock cam, and up your efficiency, even if the old cam checks good. I'll bet a radius check on the lifters would prove them to be flat, or flattening anyway..
The whole package should be updated. Your heads will run cooler and the engine will have a smoother power transition to the upper revs. |
Korijo |
Jul 19 2004, 06:33 PM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
who makes the CB Maxi pump?
Cap'n Krusty |
Jul 19 2004, 06:49 PM
Done right, a rebuild using the stock oil pump should last for years and a hundred thousand miles and up. Way up. The limiting factor is the lifespan of the heads. Over the last 31 years of wrenching on 914s, I've seen VERY few T4 motors that even needed the crank ground, much less the cam bearings and align bore work. The oil system is a phenominal improvement over previous VW engines, and the aluminum cases are relatively bulletproof. The Cap'n
Jake Raby |
Jul 19 2004, 07:15 PM
The bottom end is pretty much bulletproof.. But adding oil volume and a few oil system upgrades is always a good thing. Many stock pumps will no longer pass inspection these days. The Type I pump upgrade is something every engine that I build gets and it has definately helped with my higher revving engines along with modifying the oil passages and changing all running clearances. We picked up 12 HP on one engine just by changing the oil system for higher volume and less pressure at higher RPM!
With the DLC coating the liofespan of valves and guides may be doubling, even running .600 lift with my new roller cams! |
SpecialK |
Jul 19 2004, 07:25 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Any tech articles on this Type I oil pump mod you speak of? (IMG:style_emoticons/default/idea.gif) My spankin' new 2.0L has yet to be installed, and I can easily get to the pump with it on the stand. Now would be the time to do it.
Jake Raby |
Jul 19 2004, 07:41 PM
Gotta do it while its disassembled.. The cam gear needs modification for clearance purposes..
I just had some special bolts made for this purpose that makes it easier but all parts must be compatible. |
Korijo |
Jul 19 2004, 07:55 PM
So who makes the CB Maxi pump?
Jake ? |
Jake Raby |
Jul 19 2004, 08:07 PM
CB as far as I know...
Korijo |
Jul 19 2004, 09:29 PM
is the CB Maxi pump Any good?? 26mm gears (IMG:style_emoticons/default/confused24.gif)
Carrera916 |
Jul 19 2004, 11:03 PM
Member Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 |
Jake,
If the cam gear area needs to be modify, in terms of bolts, is it possible for us to do the work or it needs to be send out to you? What are the cost involve to get the cam gear, T1 oil pump and modified oil passage done? jerry |
Korijo |
Jul 19 2004, 11:04 PM
mine actually has 32mm gears (IMG:style_emoticons/default/w00t.gif) cant find it on CB's website, tho (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 10:47 PM |
