Steering Rack Spacers anti-bump steer |
EPK |
Jul 21 2004, 05:43 PM
Newbie Group: Members Posts: 20 Joined: 26-May 03 From: Victoria B.C Member No.: 740 |
Has anyone installed a 11-14mm steering rack spacer after the car was lowered, if so how did you do it.
Thanks for your replies, here's the problem. When the bolts are removed from the rack the rack cannot/won't move up high enough to get the spacers in. Does something else have to be loosen up to allow the rack to raise up high enough for the spacers to fit in. |
Jeroen |
Jul 21 2004, 05:48 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Had them on my 911 (has the same steering rack)
Install was nothing special. Basically you just replace the old bolts with the new (longer) ones and add the spacer Just be carefull not to crossthread the threads in the aluminium steering rack Are you having troubles? cheers, Jeroen |
Mueller |
Jul 21 2004, 05:50 PM
simplified version: remove old bolts, install spacer w/new longer bolts..
SirAndy |
Jul 21 2004, 06:05 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Mueller @ Jul 21 2004, 04:50 PM) simplified version: remove old bolts, install spacer w/new longer bolts.. and make sure the new bolts have exactly the right length, if too short, your rack will fall apart, if too long you'll crack the rack ... 10 minute install with car on lift and a bunch of "mechanics" sitting around watching you sweat and making fun of you ... (IMG:style_emoticons/default/wavey.gif) Andy |
Eric_Shea |
Jul 21 2004, 06:11 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Try this thread toward the bottom.
Lo-Fi Version | Time is now: 3rd June 2024 - 12:04 AM |
