matt_o_70 |
Newbie ![]() Group: Members Posts: 33 Joined: 6-July 04 From: rochester NY Member No.: 2,312 ![]() |
Hello,
I would like to know.. My car is missing most of the sail panel trim. Is it still available.. if so where.. is the place to get it I purchased some trunk seals from pelican and they came rolled up and the part that should push onto the body is way too tight, If i try to install it, as is, the metal inside the trim will push through the rubber and scratch the paint.. I am dissapointed with pelican parts. Is there a good way to spread the seal so that it will install properly? with out damage to seal or paint? I need to replace the targa front seals what do you with experience recommend? What is the popular consensus for the best replacement distributor / points replacement set up, pertronix. mallory, crane.. carbs at the moment but I plan some sort of FI install in the winter.. Matt |
Lo-Fi Version | Time is now: 6th July 2025 - 11:03 AM |
