Won't run under 4000 rpm |
newdeal2 |
Jul 22 2004, 11:08 AM
Unregistered |
I have a friend who is having a problem with the car running OK until it's fully warm and then it won't run under 4000 or so rpm's....???
Any ideas? It's a d jet 1974 2 Liter |
Andyrew |
Jul 22 2004, 11:10 AM
UNDER 4k?
Wrong cam? Dono.. Cloged injectors? incorrectly timed? Dwell? valves? spark? cloged fuel filter? engine toast? Dont know... Andrew |
BahnBrenner914 |
Jul 26 2004, 02:41 PM
The girl is gone and all I have now is a beat-up teener Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None |
check all the vacuum tubes. i was working on my 2.0 and forgot a vaccum tube ( i think it hooked in under the throttle body ) and fired it up. when it idled at 4000 rpm i new something was wrong.
ChrisReale |
Jul 26 2004, 02:53 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Check the timing, the TPS, do a valve adjust to make sure everything is in tip-top tune.
john rogers |
Jul 26 2004, 03:02 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I'd say an air leak. Since it happens after it gets warm it is probably a joint such as the intake manifolds to head joint or a seam on the intake plenum or some other place that can open as it gets hot. Use the carb spray with a nozzle and spray around the whole intake system and it should show up. Good luck
Lo-Fi Version | Time is now: 5th June 2024 - 06:20 PM |
