Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
I'm finishing up my interior and need to know what's the best way to fasten it to the floor? Glue, Tape, velcro?
Thanks Paul |
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
I believe they were originally glued in place. Be careful though that you get the right type of glue. Most glues will attack styrofoam. There are construction glues that are safe for foam but need one surface to be porous and might not set up when trying to stick to paint.
bigkensteele |
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States ![]() ![]() |
I would go with velcro before glue. It would afford you the ability to periodically inspect for rust, or remove it easily for whatever reason.
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,621 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
I removed mine from my '75 when I put in the Morph Subwoofer box. I don't recall it being anything but just wedged in place... I still have it sitting on a shelf if anyone needs one. (IMG:style_emoticons/default/biggrin.gif)
AZ914 |
914 Dumbass ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region ![]() |
When redoing my carpets, I just 'placed' mine back, put the carpet over it. I don't think its going anywhere.
ptravnic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None ![]() ![]() |
When redoing my carpets, I just 'placed' mine back, put the carpet over it. I don't think its going anywhere. (IMG:style_emoticons/default/agree.gif) I did the same. |
Phoenix-MN |
What I ended up doing was to buy a can of the expanding foam insulation and I sprayed four silver dollar size dots on it and pressed it in place. This will hold it and the bond can be easily broken to remove it.
Thanks for the replies Paul |
Lo-Fi Version | Time is now: 15th June 2024 - 08:24 PM |
