> Towing question,...need help!
dltalfa
post Oct 6 2011, 09:00 PM
OK,..so I sold my 914. Part of the deal was, I am to deliver it part of the way to the new owner. I will be towing it on my car trailer, first time to tow a 914.
My question is: I can't see where to tie down the rear. Where should I connect my tow straps?
Please advise
Replies(1 - 6)
avidfanjpl
post Oct 6 2011, 09:08 PM
914 Hemophiliac
I wrap Heavy Nylon straps around the space between the rotor and the wheel suspension, then hook the metal triangles on the yardlong straps to the big nylon straps at all 4 corners.
I don't actually hook any metal to any suspension part.
That way nothing gets bent.
You need 36" straps at each corner.
Borrow or rent some, if you can.
John
QUOTE(dltalfa @ Oct 6 2011, 08:00 PM) *
Please advise
BMXerror
post Oct 6 2011, 09:24 PM
I used to feed the straps between the caliper and the bearing boss casted into the trailing arm in the rear, and around the A-arm in the front. Now, I just clip into the donuts. T-hooks may work better for this. I've never tried it.
Mark D.
messix
post Oct 6 2011, 09:34 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
what wheels are on it?
dltalfa
post Oct 6 2011, 09:39 PM
QUOTE(messix @ Oct 6 2011, 10:34 PM) *
Factory Mahle's
messix
post Oct 6 2011, 09:45 PM
then around trailing arm inside of shock mount, hook to strap. pull straight back if possible
r_towle
post Oct 6 2011, 10:04 PM
Custom Member
Shocks or wheels
A-arms in the front...or wheels
Rich
- Lo-Fi Version Time is now: 7th June 2026 - 04:45 AM
