Full Version: Towing question,...need help!
dltalfa
OK,..so I sold my 914. Part of the deal was, I am to deliver it part of the way to the new owner. I will be towing it on my car trailer, first time to tow a 914.
My question is: I can't see where to tie down the rear. Where should I connect my tow straps?
Please advise
avidfanjpl
I wrap Heavy Nylon straps around the space between the rotor and the wheel suspension, then hook the metal triangles on the yardlong straps to the big nylon straps at all 4 corners.
I don't actually hook any metal to any suspension part.
That way nothing gets bent.
You need 36" straps at each corner.
Borrow or rent some, if you can.
John
QUOTE(dltalfa @ Oct 6 2011, 08:00 PM) *
Please advise
BMXerror
I used to feed the straps between the caliper and the bearing boss casted into the trailing arm in the rear, and around the A-arm in the front. Now, I just clip into the donuts. T-hooks may work better for this. I've never tried it.
Mark D.
messix
what wheels are on it?
dltalfa
QUOTE(messix @ Oct 6 2011, 10:34 PM) *
Factory Mahle's
messix
then around trailing arm inside of shock mount, hook to strap. pull straight back if possible
r_towle
Shocks or wheels
A-arms in the front...or wheels
Rich
