| dltalfa |
Oct 6 2011, 09:00 PM
Newbie ![]() Group: Members Posts: 32 Joined: 1-July 11 From: Alabama Member No.: 13,267 Region Association: None |
OK,..so I sold my 914. Part of the deal was, I am to deliver it part of the way to the new owner. I will be towing it on my car trailer, first time to tow a 914.
My question is: I can't see where to tie down the rear. Where should I connect my tow straps? Please advise |
| avidfanjpl |
Oct 6 2011, 09:08 PM
914 Hemophiliac ![]() ![]() ![]() Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
I wrap Heavy Nylon straps around the space between the rotor and the wheel suspension, then hook the metal triangles on the yardlong straps to the big nylon straps at all 4 corners.
I don't actually hook any metal to any suspension part. That way nothing gets bent. You need 36" straps at each corner. Borrow or rent some, if you can. John OK,..so I sold my 914. Part of the deal was, I am to deliver it part of the way to the new owner. I will be towing it on my car trailer, first time to tow a 914. My question is: I can't see where to tie down the rear. Where should I connect my tow straps? Please advise |
| BMXerror |
Oct 6 2011, 09:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
I used to feed the straps between the caliper and the bearing boss casted into the trailing arm in the rear, and around the A-arm in the front. Now, I just clip into the donuts. T-hooks may work better for this. I've never tried it.
Mark D. |
| messix |
Oct 6 2011, 09:34 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
what wheels are on it?
| dltalfa |
Oct 6 2011, 09:39 PM
| messix |
Oct 6 2011, 09:45 PM
then around trailing arm inside of shock mount, hook to strap. pull straight back if possible
| r_towle |
Oct 6 2011, 10:04 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Shocks or wheels
A-arms in the front...or wheels Rich |
Lo-Fi Version | Time is now: 7th June 2026 - 02:23 AM |
