D-jet sensor #2 and in cabin CHT |
lmcchesney |
Jul 25 2004, 06:30 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
I will be adding a CHT in cabin monitoring and was wondering about the sensor to use. The typical one I have seen/heard about is the copper thermocoupler in a ring fashion to be placed under the #3 spark plug. Our D-jet Type IV's have a CHT as temp sensor #2 which is read by the ECU with measurment of resistance. Is it possible to tap onto the #2 temp sensor CHT to drive a CHT in cabin gauge? My initial thinking is that tapping a gauge into the #2 sensor would alter the resistance of the circuit and thus disrupt the ECU monitoring. Do others think this is correct?
As an alternative, when using a spark plug sensor, what is the wiring circuit to the VDO CHT gauge? L. McC |
ArtechnikA |
Jul 25 2004, 07:26 PM
QUOTE(lmcchesney @ Jul 25 2004, 04:30 PM) Is it possible to tap onto the #2 temp sensor CHT to drive a CHT in cabin gauge? My initial thinking is that tapping a gauge into the #2 sensor would alter the resistance of the circuit and thus disrupt the ECU monitoring. Do others think this is correct? As an alternative, when using a spark plug sensor, what is the wiring circuit to the VDO CHT gauge? No. Yes. the thermocouple comes with wires; use them. do not cut them, do not add connectors; they must be used exactly as supplied. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:12 PM |
