> Minimum Rotor Thickness
yeahmag
post Oct 18 2011, 06:11 PM
My Chilton's (or whatever book it is) states .394" as the minimum thickness for the front rotors. Is that the correct value? Both sets I have (used) are measuring at roughly .345".
-Aaron
Replies(1 - 6)
yeahmag
post Oct 18 2011, 06:20 PM
Think I just answered my own question... I found a stamp on them on the "hat" saying minimum of .374".
Valy
post Oct 18 2011, 06:24 PM
QUOTE(yeahmag @ Oct 18 2011, 05:20 PM) *
Isn't this forum great? (IMG:style_emoticons/default/clap23.gif)
post Oct 18 2011, 07:23 PM
I've got one that is .373 and needs to be turned if you like to live on the edge. (IMG:style_emoticons/default/happy11.gif)
jcd914
post Oct 19 2011, 06:08 PM
You are asking about Front rotors, correct?
0.394 & 0.374 are both correct but different specs.
They can be machined to 0.394
they can be worn down to 0.374
Factory specs (mm): (I did the mm to in conversions)
Thickness New: 11mm +0.05mm -0.15mm (0.4331in +0.002in -.006in)
Min. Thickness after machining 10.0mm (0.394in)
Wear Limit 9.5mm (0.374in)
Jim
matt5596
post Mar 25 2013, 08:27 PM
QUOTE(jcd914 @ Oct 19 2011, 08:08 PM) *
Jim
What about rear rotors?
jcd914
post Mar 26 2013, 12:27 AM
QUOTE(matt5596 @ Mar 25 2013, 07:27 PM) *
Jim
These specs are not from a factory manual (don't know where my factory spec book is).
These are from a Peter R.D. Russek VW/Porsche 914/4 Repair Guide, I found on-line a couple years ago.
It is a nice little manual to have, little as in it fit in the glove box and can be with your 914 at all times.
All the info looks like it came from Porsche.
Thickness New: 9.5mm (0.374in)
Min. Thickness after machining 8.9mm (0.350in)
Variation in thickness 0.2mm(0.008in)
No wear limit is listed in this manual
Jim
- Lo-Fi Version Time is now: 12th March 2026 - 05:46 AM
