| seanery |
Jul 28 2004, 08:20 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I'm grinding mild steel welds on my bike to get it ready for plating.
I used this bit this evening. It only lasted an hour or hour and a half. (IMG:http://dremel.com/html/images/products/bits/large/194.gif) Is there a better bit? I've got some abrasive tips for the air powered die grinder, but I don't think the compressor will keep up with hours of grinding. |
| TimT |
Jul 28 2004, 08:38 PM
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Probably the best would be a diamond impregnated burr. But if you keep going with the steel burrs use plenty of coolant . dip the bit in an emulsion of tranny fluid and water then grind, then dip, then grind
| kafermeister |
Jul 28 2004, 08:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 778 Joined: 20-January 03 From: Cincinnati/Northern KY Member No.: 174 |
Hmm. I've never had much luck w/Dremel for grinding welds. Of course, I'm a amateur welder and I need lots of cleanup to make my work look presentable. (IMG:style_emoticons/default/biggrin.gif)
Anyway, I like to use a pneumatic die grinder with a cutoff disk to slice through the welds to set my depth. Then I use a 4" angel grinder w/abrasive grinding disk and grind down the ridges. Strangely what I've had the most success with is a plain pneumatic single action sander with 8" 25 grit disk. But it eats the metal you're trying to save as well. It's not good at localizing your grinding area. Good luck! Rick |
| seanery |
Jul 28 2004, 09:06 PM
yeah, I'm trying to make it pretty. I want to be able to remove material where I want to only.
This is what I've found at the Dremel Webpage. Would these be better than Aluminum Oxide? Attached image(s)
| bondo |
Jul 28 2004, 09:27 PM
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Carbide cutters for a die grinder are the best I've used.. they really hog out the material, you can litterally carve out the bead from an inside corner (like inside the front trunk weatherstripping groove for instance). Unfortunately they're pretty expensive. They also spray you with little metal shavings that are VERY sharp, and get under your skin quite nicely.
| Mueller |
Jul 28 2004, 09:31 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Sean,
if you have the room, I think the small cutoff wheels are better and easier to control for removing material. Attached image(s)
| Mueller |
Jul 28 2004, 09:33 PM
the problem with the carbide cutters is that it is very easy for the tool to "ran away" from you, or at least that is my experiance (too much coffee???)
| bondo |
Jul 28 2004, 09:38 PM
QUOTE(Mueller @ Jul 28 2004, 08:33 PM) the problem with the carbide cutters is that it is very easy for the tool to "ran away" from you, or at least that is my experiance (too much coffee???) I have more trouble with that using dremel tools than with die grinders.. not sure why. |
| lapuwali |
Jul 28 2004, 09:48 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
My experience with the Dremel cutoff wheels is they don't last very long. The medium brown colored ones that look like something pressed together last only a few seconds cutting steel, and break very easily. The fabric-looking ones last longer, but still rarely more than a few minutes. You can actually watch the things shrink. You seem to remove about as much material off the wheel as you do steel from the weld...
There's a speed control you can get for a Dremel that will allow you to slow it down a good bit, which might help. I have a variable speed Ryobi with a flex shaft, and slower speeds seem to extend the life of cutters and grinders a bit, but only a bit. I think the slowest speed on this thing is still way too fast. My air grinder is quite a bit slower. |
| Mueller |
Jul 28 2004, 09:58 PM
I had to use a dremel cutoff wheel last week to remove the head of a stripped CV joint bolt (IMG:style_emoticons/default/sad.gif)
| thomasotten |
Jul 28 2004, 11:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,572 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I used the carbide tip to remove the jack post support on the passenger side of the teener. Worked great. You know, how you can hardly get to the top part of it, unless you remove the fender. Actually, part of it is still up there. (IMG:style_emoticons/default/rolleyes.gif) I used a RotoZip to cut most of the sheetmetal, but they wear out quick just like the Dremels.
| IronHillRestorations |
Jul 29 2004, 12:02 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,921 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Dremel is a good tool, but it's a hobby tool. If you use it for grinding welds it won't last very long. It's ok for small jobs, but it won't take much pressure.
I use the cut-off tool, a die grinder with carbide burrs, a 4" angle grinder, and a angle die grinder with roloc abrasive discs. Oh, and with eye protection, leather gloves, ear plugs, etc. Don't ask why... PK (IMG:style_emoticons/default/cool.gif) |
| J P Stein |
Jul 29 2004, 02:05 AM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
| seanery |
Jul 29 2004, 08:11 AM
Alright, I'll give the air tools a shot. I hope it can keep up. (IMG:style_emoticons/default/wacko.gif)
| jonwatts |
Jul 29 2004, 08:57 AM
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
QUOTE(seanery @ Jul 29 2004, 06:11 AM) Alright, I'll give the air tools a shot. I hope it can keep up. (IMG:style_emoticons/default/wacko.gif) Don't you want the justification to buy a new compressor? I agree with the dremel assessment. They're great for close quarters work but for big jobs you'll go broke buying bits. No personal experience on these but I saw a guy using them (or something like them) on Horsepower TV to remove trunk welds on an old Nova. The holes allow you to see where you're grinding. (IMG:http://www.eastwoodco.com/images/us//local/products/detail/p18410.jpg) Available at Eastwood |
| mightyohm |
Jul 29 2004, 09:34 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,279 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
QUOTE(Mueller @ Jul 28 2004, 07:33 PM) the problem with the carbide cutters is that it is very easy for the tool to "ran away" from you, or at least that is my experiance (too much coffee???) I have had this experience also. They tend to bite in and gouge at exactly the wrong time. I always end up making a bigger cut than I intended. |
| seanery |
Jul 29 2004, 11:03 AM
| J P Stein |
Jul 29 2004, 11:57 AM
That cone radius ruby is one of those I use.....and that's a very good price. Dunno the difference...but at those prices, get one of each in the 1/4 or 5/16 size & see which you like. I get em' at a tool supply outfit up the street for about 12 bucks each. (IMG:style_emoticons/default/sad.gif)
| seanery |
Jul 29 2004, 04:27 PM
I ended up buying these carbide bits from the vendor listed above. 8 bits delivered for $45. Seems like a deal to me (IMG:style_emoticons/default/biggrin.gif)
| seanery |
Jul 29 2004, 04:31 PM
One more question, cutting oil or no cutting oil?
Lo-Fi Version | Time is now: 13th March 2026 - 11:42 AM |
