Replacement Defroster Hose |
kconway |
Oct 19 2011, 08:26 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Obscure for sure. I need a passenger side defrost heat tube (1974) that is apparently NLA. Anyone have a lead on an acceptable replacement.
Kev |
76-914 |
Oct 19 2011, 08:54 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Kevin, I'n confused. Are you looking for the flexible hose of a steel part?
AndyB |
Oct 19 2011, 09:13 AM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
If you are talking about the flexible hose between the elbo and the flapper I got mine from CFR-Tangerine Racing. I have had no issues it fit fine with clamps.
kconway |
Oct 19 2011, 10:05 AM
This is a hose up under the front cowl that blows warm air up on the windshield to defrost it, not in the engine compartment. It's like 60mm or something close to that, a third smaller then all the other hoses in the warm/fresh air system.
tod914 |
Oct 19 2011, 10:19 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Kevin the brown cardboard covered foil hose? I recall someone sourcing some a while back. One of the CW guys.. Maybe ask Tom T or Pat G. They might recall.
76-914 |
Oct 19 2011, 10:28 AM
Here ya go........... http://www.aircraftspruce.com/catalog/appages/scat.php
Valy |
Oct 19 2011, 11:13 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
You need the cardboard hose. The newer version is black.
Check if you need 55 or 60MM. I think the early models used 55MM 60MM --> PN: 911 211 522 00 or 911 211 522 01 55MM --> http://www.thepartsbin.com/catalog/?N=&...amp;x=0&y=0 Two pieces will replace all your hoses and you'll have about 2ft leftover. |
Chris Pincetich |
Oct 19 2011, 01:58 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I got both the large and small hoses from Pelican parts. Call them
The new ones are shiny black on the outside, foil on the inside Porsche part #'s I still have a short bit left-over from replacing the small front one under the cowl, and an un-touched big hose I don't think I will need to replace (the one from under cowl to behind speakers inside). PM me if interested in buying that big hose or the small piece of the smaller one. (IMG:style_emoticons/default/beerchug.gif) |
SirAndy |
Oct 19 2011, 03:37 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Obscure for sure. I need a passenger side defrost heat tube (1974) that is apparently NLA. Anyone have a lead on an acceptable replacement. A few years back (two maybe?) those hoses were already NLA and the guys at EASY found a suitable replacement (911 part?). I bought two of them for my car and they were a perfect fit. Give them a call: http://www.easypor.com/ (IMG:style_emoticons/default/bye1.gif) |
nsr-jamie |
Oct 19 2011, 05:08 PM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Mark (Mikey914) at 914 rubber.com has them too though they are not listed on his site, he makes heavy duty ones that I just ordered.
kconway |
Oct 19 2011, 05:28 PM
pda914 |
Oct 19 2011, 06:36 PM
Newbie Group: Members Posts: 40 Joined: 22-July 10 From: Verona WI Member No.: 11,966 Region Association: None |
check Nostalgic Air Parts
www.nostalgicairparts.com |
Mikey914 |
Oct 19 2011, 06:52 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have the defroster ones and the ones between the airbox and mixer.
Just let me know. The defroster ones are smaller. I had not listed on the website as I don't sell a lot of them. They are not the cheap paper ones. They have spring steel layered in them so they are hard to crush. $20 a set. -Mark |
kconway |
Oct 19 2011, 07:08 PM
pete000 |
Oct 19 2011, 08:36 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
The brown OE ones seem to be all gone, AA said they had some, but when I ordered them they came in black. Seems that Porsche still supplies them in black which is what I ended up using. They had Porsche part labels on them.
Looks like the brown ones are going to get valuable if they are good shape. |
Mikey914 |
Oct 20 2011, 12:06 AM
The problem with the brown ones is they are aluminum with a paper wrap.
barada |
Oct 24 2011, 02:32 PM
Member Group: Members Posts: 257 Joined: 5-October 08 From: Atlanta Member No.: 9,613 Region Association: None |
I could not find the brown ones and did not want to use the HI temp ones. I found the Black ones from Myco Parts. These guys are local and really cool to deal with.
http://mycoimportedparts.com/ Thanks Phillip |
Lo-Fi Version | Time is now: 10th June 2024 - 03:26 AM |
