| buck toenges |
Jul 29 2004, 12:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 554 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None
I am running a 3.2 with a k+n filter and maf. It has a velios oil tank. My oil is becoming milky. I assume there is some condensation issues going on but I also think the induction system of the air filter being exposed to the elements causing some of this. I have been told to run the beast for a while to burn off the water. What else should I do? Is there a way to protect the air filter from the wet? (IMG:style_emoticons/default/huh.gif)
| seanery |
Jul 29 2004, 01:11 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I think the person was right. IIRC, your oil is not getting up to temp. Run it good and hard. (IMG:style_emoticons/default/driving.gif)
| Jeroen |
Jul 29 2004, 01:24 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Yep, too many short distances will do that
Give the car a good run for it's money If you think it's really bad, refresh the oil cheers, Jeroen |
| J P Stein |
Jul 29 2004, 01:32 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
If the oil is visibly "milky", I'd drain it and start again.
I try not to fire mine up unless I'm gonna run it for 15-20 minutes minimum....more is better. |
| SirAndy |
Jul 29 2004, 02:16 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,473 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:style_emoticons/default/agree.gif) drive it and get it warmed up. go for a 200-300 mile trip on some windy backroad and let her play.
then, change the oil to something good, like mobile1 ... (IMG:style_emoticons/default/driving.gif) Andy |
| tdgray |
Jul 29 2004, 02:22 PM
Thank God Nemo is not here to see this ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,706 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Sounds like you have a blown head gasket right on the water jacket (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 15th April 2026 - 05:41 AM |
