Can this be cleaned |
914itis |
Oct 20 2011, 07:45 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Can this distributor be cleaned? it looks preety dirty and somewhat rusty inside. How do I clwan it?
Andyrew |
Oct 20 2011, 07:47 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
914itis |
Oct 20 2011, 07:52 PM
You are right!
sorry |
Andyrew |
Oct 20 2011, 07:59 PM
Anything electrical in there or just mechanical? Carb cleaner would probably break apart most of it.
But I havent touched those dizzy's in years so I dont know if it would be bad for it or not.. |
914itis |
Oct 20 2011, 08:06 PM
John |
Oct 20 2011, 08:33 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
#1 is the breaker plate ground wire.
#2 is a holder for a ball bearing (as I recall) The ball bearing is supposed to allow the breaker plate to rotate from the vacuum advance can. |
John |
Oct 20 2011, 08:35 PM
It sure looks like the green wire has melted badly. The green wire hooks to the breaker points (not present in your distributor) and then to the condenser and to the coil. The wire is part of the condenser when you get a new one.
somd914 |
Oct 20 2011, 08:44 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
#1 is the breaker plate ground wire. #2 is a holder for a ball bearing (as I recall) The ball bearing is supposed to allow the breaker plate to rotate from the vacuum advance can. That is correct. Given the condition up top, the mechanical advance unit below the breaker plate is probably as bad or worse. I wouldn't be surprised if you are not getting any advance - vacuum or mechanical. Try twisting the rotor, it should move perhaps a half inch as measured at the end, then spring back. If it springs back, the advance system is not bound up. I'd take the breaker plate out, clean it up, examine the mechanical advance system, if rusty hit it with penetrating oil like Tri-Flow, work it free, put everything back together, then don't forget to put a few drops of oil on the felt in the center of the shaft - keeps the advance mechanism lubricated. Check your timing after all this. Went through all this a few months. Not much work, made a big difference. |
r_towle |
Oct 20 2011, 09:25 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Yes, it can be completely disassembled , cleaned and rebuilt....all for a few bucks and your time.
Rich |
Valy |
Oct 21 2011, 12:20 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
slu234 |
Oct 21 2011, 07:45 AM
Member Group: Members Posts: 57 Joined: 20-January 09 From: Staunton, VA Member No.: 9,949 Region Association: MidAtlantic Region |
The little "green" wire is the grounding strap to ground the points plate to the dizzy body. If it is toast you can buy some de-soldering floss and solder in a replacement. The desoldering floss is a flat braid of fine copper - soft flexible and works great.
Brian |
Jasfsmith |
Oct 21 2011, 08:59 AM
Senior Member Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States |
The little "green" wire is the grounding strap to ground the points plate to the dizzy body. If it is toast you can buy some de-soldering floss and solder in a replacement. The desoldering floss is a flat braid of fine copper - soft flexible and works great. Brian I've never seen the grounding strap having a sheath on it. I suspect the strap is the original braided copy that has oxidized to the color green. |
Dave_Darling |
Oct 21 2011, 05:45 PM
I think he means the green wire outside of the distributor body, upper right in the picture. It looks pretty melted, so you really want to replace the consdensor (which has that green wire as part of it).
--DD |
914itis |
Oct 21 2011, 05:52 PM
I think he means the green wire outside of the distributor body, upper right in the picture. It looks pretty melted, so you really want to replace the consdensor (which has that green wire as part of it). --DD No I meant Inside the distributor. I am aware that the wire is melted . Planing on using a compufire anyway . Not using points. |
underthetire |
Oct 21 2011, 06:09 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Got a ultrasonic cleaner? Take it apart and throw it in. It will come out clean.
Lo-Fi Version | Time is now: 10th June 2024 - 04:48 PM |
