> turbo on a stock 4cyl
Ctrout
post Aug 1 2004, 02:30 PM
I did a search for "turbo" and was surprised that I didn't find any threads on adding a turbo to a stock 1.7, 1.8, or 2.0. Is this not a possibility or just not a good idea because of reliability and longevity issues? What would be better for 160-180hp, turbo a 1.8 or swap in a 6? What would be cheaper?
Replies(1 - 19)
Jeroen
post Aug 1 2004, 02:40 PM
Region Association: Europe
Strange... the search should have come up with something, cause we had more than a couple of turbo threads here
cheers,
Jeroen
Jeroen
post Aug 1 2004, 02:42 PM
You didn't use the search function properly
Try clicking here
cheers,
Jeroen
Ctrout
post Aug 1 2004, 02:46 PM
I got the same three pages but didn't see anything that talked about torbo on a 4 cyl engine.
Jeroen
post Aug 1 2004, 02:53 PM
Actually, the "turbo" search comes up with 53 pages...
Happy browsing (IMG:style_emoticons/default/biggrin.gif)
cheers,
Jeroen
mikester
post Aug 1 2004, 03:24 PM
"You can't turbo a 914."
(IMG:style_emoticons/default/boldblue.gif)
Mueller
post Aug 1 2004, 03:53 PM
914 Freak!
depends on a lot of things....
if you have to pay someone to add the turbo to your car, (@$50 an hour or so, minimum) it might be cheaper to do a six....then again, if you have to pay someone to do the /6 conversion, it might be cheaper to do the turbo (IMG:style_emoticons/default/smile.gif)
there are at least 2 people on the BBS running /4 motors with a turbo, one did it himself and the other one bought the car with it installed.....
Everything is pretty much custom, there will not be a simple bill of materials and instructions available..it's one of those things that if you have to ask about it, forget it unless you have deep pockets or can do 90% of the work yourself......you should start off buying a few books on the subject if you are serious about it...
physician
post Aug 1 2004, 04:11 PM
still looking for a teener....
someone bought Ed Villelas turbo /4 a few months ago, search for it
Mark Henry
post Aug 1 2004, 04:16 PM
that's what I do!
By the time you buy/fab/figure everything out and beef the engine, you could have built a N/A engine that makes as much power and is reliable.
Joe Bob
post Aug 1 2004, 04:30 PM
Do it right...grab a 930 motor and stuff it in....
mxdude914
post Aug 1 2004, 09:29 PM
i really want to know about how much it would cost to have it done or do it yourself and what would be reguired
Ctrout
post Aug 1 2004, 09:37 PM
Custom exhaust, turbo unit, blow-off valve, oil lines for the turbo, intercooler if you want better efficiency. I've never done it before but I have looked into it a bit. I'm trying to think of any other major parts or fabrication needed. Maybe it would be easier to supercharge it.
mxdude914
post Aug 1 2004, 09:44 PM
what would be diff. about supercharger
Ctrout
post Aug 1 2004, 09:48 PM
Superchargers are belt driven. No need for a custom exhaust. A supercharger setup costs around 2-3k I think.
mxdude914
post Aug 1 2004, 09:53 PM
how much would a turbo setup cost done yourself
Ctrout
post Aug 1 2004, 09:57 PM
Most of the parts can be had used for very low cost. You would need the exhaust though. You could probably do it for $1000 or less if you set your mind to it. That doesn't mean that the stock motor could handle the power. You would probably want to do a full rebuild with quality parts. especially the pistons and rods. Might want to figure out how to incorporate knock sensing stuff too so you won't blow up any pistons.
mxdude914
post Aug 1 2004, 10:23 PM
do you know where there might be some info on how i could do it and about how much power it might have in the end starting with a stock 2.0
andys
post Aug 1 2004, 11:04 PM
I had a turbo on my '73 914/4 back around 1975. The kit was manufactured by Crown as I recall, and used a Rayjay turbo. I doubt they make the kit any longer, or if they're even still in business.
Andy
Mueller
post Aug 1 2004, 11:14 PM
914 Freak!
nope, no longer in business, myself and a few others have tried to track them down with no luck...Gene Berg made a kit, sold only a few and the Mark guy that makes headers (and has the horizontal fan turbo'd /6 914) use to make a kit....only a few sold, he no longer has any parts or drawings
a few of the more recent turbo installs have used CIS which came factory on a few turbo cars (Audi and others)
programmable electronic fuel injection is the only way to go in my opinion now that they are much cheaper....
I'm going to turbo my 1.8, for the exhaust, I am using a European Racing header...the turbo will be mounted right off of the collector...megasquirt will supply fuel
...it'll basicly be a /4 version of imchappys turbo'd 3.0 914
mxdude914
post Aug 1 2004, 11:16 PM
do you have any deeper specifications and instructions on how you will do it and can you use any turbo
- Lo-Fi Version Time is now: 11th July 2025 - 08:22 AM
