Outer door seal, This one is for mickey914 |
914itis |
Oct 30 2011, 01:50 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
After installing the new outer door fuzzy from 914rubber, the window becomes hard to roll up and down, at one time the seal came off the track as I try to put it down.. if i spray the window with Windex it comes up and down as it should. any ideas? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
partwerks |
Oct 30 2011, 02:19 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The only thing I could even begin to think of is, maybe something else got out of alignment during the process causing it to rub against it to the point of pushing it up, but when going down also??
914itis |
Oct 30 2011, 02:23 PM
Yep both ways
partwerks |
Oct 30 2011, 02:28 PM
Have you had this door all apart previously? If so, maybe you didn't get something back in place.
Were talking about that fuzzy strip on both sides of the window, correct? |
partwerks |
Oct 30 2011, 02:32 PM
I don't know. Maybe the window is tilting out too far and rubbing?
Does that nut on the bottom of the door towards the rear adjust the window or is there something maybe up with that??? |
Mike Bellis |
Oct 30 2011, 02:56 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I have the same problem. The rubber grabs the glass and pops out of the groove. I solved it by removing the rubber and living without it. I know, not much of a fix... I will try again after I get it painted. BTW, it happens on both doors.
914itis |
Oct 30 2011, 03:04 PM
Have you had this door all apart previously? If so, maybe you didn't get something back in place. Were talking about that fuzzy strip on both sides of the window, correct? correct, Everything is back in place. The window is straight. As I mentioned, if i spray the window it is fine. The rubber is grabbing on the window. I also made sure that the window is clean. |
914itis |
Oct 30 2011, 03:05 PM
I don't know. Maybe the window is tilting out too far and rubbing? Does that nut on the bottom of the door towards the rear adjust the window or is there something maybe up with that??? I never touched that screw, you mean the one holding the rear rail? will check that later. |
Mike Bellis |
Oct 30 2011, 03:06 PM
Soaking the rubber in a bucket of Armor All may do the trick. I havn't tried yet.
914itis |
Oct 30 2011, 03:12 PM
Soaking the rubber in a bucket of Armor All may do the trick. I havn't tried yet. I will make sure I have some Windex in the glove compartment. or beer may do it (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
partwerks |
Oct 30 2011, 04:07 PM
squirt on a bunch of Rain X.........
Maybe that will help. |
Tom_T |
Oct 30 2011, 08:04 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Soaking the rubber in a bucket of Armor All may do the trick. I havn't tried yet. Don't use ArmourAll..... (IMG:style_emoticons/default/blink.gif) Try something like Wurth Rubber Care spray on the rubber part (not the fuzzy one) instead of ArmourAll - since the latter gets sticky over time. Most of us that used it on our interior vinyl back-in-the-day later had sticky vinyl. Otherwise, contact Mikey914/Mark W. for help - he made them, & would be glad to give tips I'm sure! (IMG:style_emoticons/default/biggrin.gif) |
smg914 |
Oct 30 2011, 08:34 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
Wax your windows, in and out.
Black22 |
Oct 30 2011, 08:48 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Wax your windows, in and out. (IMG:style_emoticons/default/agree.gif) Mine grabbed and pulled when first installed. Spray wax does a good job of fixing it. Over time it won't be an issue. There just grabbing because it's fresh rubber. |
914itis |
Oct 30 2011, 08:52 PM
Wax your windows, in and out. (IMG:style_emoticons/default/agree.gif) Mine grabbed and pulled when first installed. Spray wax does a good job of fixing it. Over time it won't be an issue. There just grabbing because it's fresh rubber. you mean regular wax that you use in the car paint? |
smg914 |
Oct 30 2011, 09:04 PM
Yup
Mike Bellis |
Oct 30 2011, 09:08 PM
Until you drive a couple of times with the window down... Your elbow will make it come loose too...
Lo-Fi Version | Time is now: 22nd May 2024 - 10:47 PM |
