| bigkensteele |
Nov 2 2011, 07:54 PM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
It is too long to be the alternator bolt, and that one is accounted for. I vaguely remember seeing it before, but I can't remember what/where it came from. To give you an idea of where it could have come from, I will tell you where I have been. - removed engine/tranny (75 1.8) - rebuilt tranny - took engine down to shortblock, replaced accessable seals, did a lot of cleaning and painting - removed gas tank, replaced all soft lines, filter - ran SS fuel lines in the tunnel - replaced all vacuum hoses - replaced 1.8 exhaust with SSEs, 2.0 ducting and a bursch Getting ready to put the motor back in, but I would really like to find the home for this thing. I have a feeling it could be important. Thanks, Ken |
| Valy |
Nov 2 2011, 08:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I bet this is not a metric bolt and probably not from your car.
Can you measure the diameter and thread? |
| McMark |
Nov 2 2011, 08:14 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Lower alternator mount bolt.
Pic is a 912E engine, but same difference. (IMG:style_emoticons/default/wink.gif) Attached image(s)
| bigkensteele |
Nov 2 2011, 09:00 PM
I bet this is not a metric bolt and probably not from your car. Can you measure the diameter and thread? Looks like you might be correct. I thought that it was M6, but an M6 nut would not fit. I am starting to think that this didn't come from the car, but I can't figure out how it ended up in my "cleaned parts" area. Thanks! |
| bigkensteele |
Nov 2 2011, 09:05 PM
Lower alternator mount bolt. Pic is a 912E engine, but same difference. (IMG:style_emoticons/default/wink.gif) Nope, it is probably about 1.5" too long for that, and I already mounted the alternator with the correct bolt. After reading Valy's post above, I tried an M6 nut on it, and it appears to be SAE. So, I am guessing this came from somewhere else, but I can't think for the life of me where it would have come from, much less ended up in the area I reserved for parts that I have cleaned for reassembly. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 18th March 2026 - 05:15 PM |
