> Car is done (sort of), After 20 years
Phoenix-MN
post Nov 4 2011, 05:36 PM
Well, Chappy lit a fie under my A$$ last summer to git'er done. So after 20 years since I started, here it is (IMG:style_emoticons/default/piratenanner.gif)
All done except a few minor things, just in time for winter (IMG:style_emoticons/default/headbang.gif)
Paul
Replies(1 - 16)
raw1298
post Nov 4 2011, 05:45 PM
Very nice!! I like the boxster muffler.
pt_700
post Nov 4 2011, 05:57 PM
more about the interior, please! is that a getty dash?
engine from a buick grand national (turbo v6)?
i like the radiator install. looks like you've left room for a spare?
you're kind of teasing us but, it's oh so sweet!
Krieger
post Nov 4 2011, 05:58 PM
Nice work! Now drive it before it MN freezes over.
Phoenix-MN
post Nov 4 2011, 06:02 PM
QUOTE(pt_700 @ Nov 4 2011, 03:57 PM) *
Getty? No, it's a full dash from a 78 911SC. The engine started life as a NA 3.8L. Yes a space saver spare is fitted to the front.
More pictures and info are on the web site:
http://phoenixhobbies.com/html/project_914.html
rohar
post Nov 4 2011, 06:12 PM
Two of you in one night getting them off the jack stands, something is wrong with the 914 universe.
rick 918-S
post Nov 4 2011, 06:17 PM
Hey nice rack! -Celette
Congradulations Paul. It's all down hill from here!
914.SBC
post Nov 4 2011, 06:35 PM
She is purdy....real, real, purdy. What is the engine?
Tom
post Nov 4 2011, 06:36 PM
Good job, Paul! (IMG:style_emoticons/default/smilie_pokal.gif) That is one nice looking 914 and I bet it goes really nice too.
Tom
iamchappy
post Nov 4 2011, 07:05 PM
It all happens so fast!
This is one beautiful car, Pauls attention to detail is to the highest level. (IMG:style_emoticons/default/smilie_pokal.gif)
I am so glad to see er done, we all have had to suffer through our setbacks as you did on Das3.8, enjoy the ride while we still have some nice weather. Maybe we should do one last drive together before the weather turns, grab some photo's for all to enjoy....
Oh, and next time we race i wont be holding onto a cup of hot coffee .....
For all of you, Paul and i let off right in time as there were 2 patrol cars up at the next intersection plus Ollie and i and the cars interior was doused in our coffee, i think i was a little ahead...but that's debatable......Paul said he lifted.......but he also had a jump start on me... after my turbo lag and blast off as i remember i was juggling a coffee cup and i was a little ahead... it all happened so fast, Paul is the only one who really knows....
bulitt
post Nov 5 2011, 05:18 AM
Achtzylinder
QUOTE(iamchappy @ Nov 4 2011, 09:05 PM) *
Awesome Car! Great Work!
BajaXJ92
post Nov 5 2011, 05:53 AM
Extended Member
QUOTE(Phoenix-MN @ Nov 4 2011, 08:02 PM) *
Would love to see some more detailed pictures of your space saving spare bracket! I'm going to do the same thing for my V8 car to try to ballast some weight forward in the car and retain rear trunk space.
I see you have the tire mounted more towards the drivers side, any reason for that other than clearing your coolant resevoir? Does it affect airflow much, if at all? Did you have to remove the gas tank or did you just tack a bracket to that front wall? Any bracing?
saigon71
post Nov 5 2011, 06:50 AM
Great looking car - fine work! (IMG:style_emoticons/default/beerchug.gif)
Phoenix-MN
post Nov 5 2011, 07:46 AM
QUOTE(BajaXJ92 @ Nov 5 2011, 03:53 AM) *
I mounted it to the side to make for more clearance around the cooling lines , fuel pump and filter. Along with the bracket I made a cradle to support the weight of the spare tire so it did not only hang by the bracket. The car was completely dis-assembled when I put in the bracket so the was no worries about a gas tank. So far I've had no problems with cooling.
Phoenix-MN
post Nov 5 2011, 08:05 AM
QUOTE(914.SBC @ Nov 4 2011, 04:35 PM) *
It's a 3.8L Buick RWD V6. .030 over with 9.5:1 pistons, Lunatti BM II cam, Harland Sharp roller rockers, Cloyes Double roller timing chain. Manley performance SS valves, Some head porting, Sanderson headers, Holley intake and a Holley HP fuel injection system. I have no real numbers on hp but it should be around 275hp which is a good balance for a car of this size.
strawman
post Nov 5 2011, 09:57 AM
QUOTE(Phoenix-MN @ Nov 5 2011, 06:46 AM) *
Great build!
Are you using heat-shrink on the coolant hoses in the pic above? I have seen that stuff mentioned but have never used it. How is your experience with it?
Geoff
Phoenix-MN
post Nov 5 2011, 10:59 AM
QUOTE(strawman @ Nov 5 2011, 07:57 AM) *
Great build!
Geoff
Yes, it's a heat shrink band made by Gates. Absolutely no leaks and it self tightens with every heat cycle. Only drawback is that it's not servicable, you have to use a new one if you take it apart. They're only a couple of bucks and make for a much cleaner installation.
- Lo-Fi Version Time is now: 2nd April 2026 - 08:40 PM
