turn signal demons.... |
scottb |
Apr 26 2003, 12:47 PM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
so i took the teener to get inspected and the right front turn dual filament light was not working when the lights were turned on. no big deal, i just put in a new one. now here is the weird thing.
once i put in the new bulb, the turn indicator was really dim in the front and on the dash, both indicators would light up dimly. the steady light works just fine with the headlights on. sounds like a short but just from changing a bulb? i am confused. |
Anton |
Apr 26 2003, 02:13 PM
Royal Orange Group: Members Posts: 161 Joined: 25-March 03 From: The Netherlands Member No.: 473 |
Scott,
Sounds like a problem with the relay since the steady light works properly. This makes a ground connection problem less likely as the dual lightbulb has one common minus side. I would pull the relay off the fuse box plate and then push it back in to see if that solves the problem. Otherwise, exchange the relay. Anton |
Anton |
Apr 26 2003, 02:25 PM
Unless... you have installed the bulb the wrong way around as it contains both a 5 and 21 Watt light. (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 08:15 PM |
