Side shifter upgrade, need new engine mount?? |
jr91472 |
Aug 5 2004, 08:13 AM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
I read a Technical Article that stated to swap out a tail shifter for a side shifter, you needed a late model engine mount.
Is this true? If so, how late? my teener is a '72. thx |
ArtechnikA |
Aug 5 2004, 08:19 AM
QUOTE(jr91472 @ Aug 5 2004, 06:13 AM) I read a Technical Article that stated to swap out a tail shifter for a side shifter, you needed a late model engine mount. Is this true? If so, how late? late enough for the car to have had a side shifter ... |
rhodyguy |
Aug 5 2004, 08:54 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you will need a bar from a 73 or later. it has a large cast hole that the rod passes through. you are going to need the 2 brackets that bolt to the front of the block, 2 rubber mounts that go in between the brackets and the bar, and 2 of the solid outboard pieces that replace the earlier outboard style. plan on buying the replacement/adapter firewall bushing with the correct outside diameter for the early hole and the correct inside diameter for the later rod.
kevin |
jr91472 |
Aug 5 2004, 01:44 PM
thanks rhodyguy,
I had not consider the point regarding the firewall bushing. JR |
Lo-Fi Version | Time is now: 10th June 2024 - 03:43 AM |
