Copper Fuel Lines |
Copper Fuel Lines |
chris914 |
Aug 7 2004, 01:37 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
Has anyone ever replaced their plastic fuel lines with copper instead of steel? The reason is that it would be easier then getting the steel ones in. I have seen this done on sand rails before.
Thanks, Chris. |
McMark |
Aug 7 2004, 01:43 PM
Copper will break more easily that steel from bending.
Andyrew |
Aug 7 2004, 02:36 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Go to your flaps and buy some steel brake lines.. like in 6f or so increments..
Kragen should have em, pep boys should, autozone.. bla bla bla Andrew |
tracks914 |
Aug 7 2004, 09:03 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Copper is Ok for something you race and can have easy access too. It work hardens if there is vibration and will crack on you. Don't use it unless you have good fire insurance and you car is insured for 20K.
IronHillRestorations |
Aug 8 2004, 10:19 AM
I. I. R. C. Group: Members Posts: 6,720 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
This has been gone over numerous times before. Here's the last thread I could find.
http://www.914world.com/bbs2/index.php?act...pper+fuel+lines My 914 Guru/yoda-zenmaster Brad Mayeur has put copper lines in 914's for over twenty years with know known issues. All of the paranoia over this is internet speculation/bs. As long as you do it correctly, aren't achieving an altitude (ie aircraft) or plan to campaign the car in F1, and use some common sense. You'll be OK. PK (IMG:style_emoticons/default/cool.gif) I'm still waiting for photos of one 914 with failed copper fuel lines. |
SpecialK |
Aug 8 2004, 10:51 AM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
I you're using some kind of isolator (rubber fuel line) between the tank and the F/I or carbs, there will be no "work hardening" issues. It'll also handle any psi the fuel pump can through at it, I've personally seen A/C units run over 400 psi (on a hot day with a clogged condenser). |
ThinAir |
Aug 8 2004, 04:52 PM
Best friends Group: Members Posts: 2,542 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I'm about to do the fuel pump relocation project myself and after reading tales of how hard it is to bend the steel lines I wondered why copper wouldn't work. Is the copper line that I would find at my local hardware store acceptable or do I need to go to a plumbing supply and ask for something particular?
Lo-Fi Version | Time is now: 23rd May 2024 - 07:16 AM |
