Rebuilt motor, cam identification |
Cool914 |
Nov 14 2011, 09:12 PM
Member Group: Members Posts: 98 Joined: 25-January 11 From: Ontario Member No.: 12,627 Region Association: Canada |
I picked up a freshly rebuilt 2.0 engine awhile back but don't have much history on it. It seems it was set up for carbs and I will be using Djet and worried it could be a cam that will not be friendly to Djet. Is there any easy way to tell what cam I have, is there a marking on the end of them that I could see if i pulled the oil pump?
I dont want to intall it and set up the djet to test it out, I have a running 1.7 in for the meantime, rather break down the rebuilt to have a looksy over the winter, was going to do that anyway to make sure it looks all good (heads/pistion), but rather not split it if I don't have to. If i have to do that I will probably change it to a 2056 while I am there, and from what I have read a 9550 would be the way to go if so. If anyone has a an extra mount for the 2.0 air box (the one that goes on the intakes) let me know, it's the one missing peice I need for the 20 setup. thanks |
Valy |
Nov 14 2011, 09:52 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I picked up a freshly rebuilt 2.0 engine awhile back but don't have much history on it. It seems it was set up for carbs and I will be using Djet and worried it could be a cam that will not be friendly to Djet. Is there any easy way to tell what cam I have, is there a marking on the end of them that I could see if i pulled the oil pump? I dont want to intall it and set up the djet to test it out, I have a running 1.7 in for the meantime, rather break down the rebuilt to have a looksy over the winter, was going to do that anyway to make sure it looks all good (heads/pistion), but rather not split it if I don't have to. If i have to do that I will probably change it to a 2056 while I am there, and from what I have read a 9550 would be the way to go if so. If anyone has a an extra mount for the 2.0 air box (the one that goes on the intakes) let me know, it's the one missing peice I need for the 20 setup. thanks Aftermarket cams are usually stamped on the end that's visible by removing the oil pump. |
Cool914 |
Nov 15 2011, 08:24 PM
I picked up a freshly rebuilt 2.0 engine awhile back but don't have much history on it. It seems it was set up for carbs and I will be using Djet and worried it could be a cam that will not be friendly to Djet. Is there any easy way to tell what cam I have, is there a marking on the end of them that I could see if i pulled the oil pump? I dont want to intall it and set up the djet to test it out, I have a running 1.7 in for the meantime, rather break down the rebuilt to have a looksy over the winter, was going to do that anyway to make sure it looks all good (heads/pistion), but rather not split it if I don't have to. If i have to do that I will probably change it to a 2056 while I am there, and from what I have read a 9550 would be the way to go if so. If anyone has a an extra mount for the 2.0 air box (the one that goes on the intakes) let me know, it's the one missing peice I need for the 20 setup. thanks Aftermarket cams are usually stamped on the end that's visible by removing the oil pump. Thanks, do you know if original cams are marked? |
Valy |
Nov 15 2011, 08:45 PM
I picked up a freshly rebuilt 2.0 engine awhile back but don't have much history on it. It seems it was set up for carbs and I will be using Djet and worried it could be a cam that will not be friendly to Djet. Is there any easy way to tell what cam I have, is there a marking on the end of them that I could see if i pulled the oil pump? I dont want to intall it and set up the djet to test it out, I have a running 1.7 in for the meantime, rather break down the rebuilt to have a looksy over the winter, was going to do that anyway to make sure it looks all good (heads/pistion), but rather not split it if I don't have to. If i have to do that I will probably change it to a 2056 while I am there, and from what I have read a 9550 would be the way to go if so. If anyone has a an extra mount for the 2.0 air box (the one that goes on the intakes) let me know, it's the one missing peice I need for the 20 setup. thanks Not marked Aftermarket cams are usually stamped on the end that's visible by removing the oil pump. Thanks, do you know if original cams are marked? |
Lo-Fi Version | Time is now: 11th June 2024 - 06:44 AM |
