New York City: 2002 a4 big turbo""fast"" (Tuckahoe) $7995 |
914World |
Nov 15 2011, 12:53 AM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
Brand new Stasis Tracksports (extra set of Street Sport springs) Porsche Cayenne frt. calipers, x-drilled ML55 rotors with Hawk HPS pads, all new B6S4 rear calipers, x-drilled rotors with Hawk HPS pads, all new VMR V710 wheels 19x8.5 w/Kuhmo Ecsta 235/35/19 less then 8k miles on wheels and tires. RS4 rear sway bar LESS THEN 10K MILES ON THE ABOVE, AND LESS THEN 15K MILES ON EVERYTHING BELOW Eurocode 2.0L short block, JE pistons, Scat Rods, Eurospec forged, knifedged lightweight crank Ported and polished AMB head, with Ferrea SS valves, springs, and titanium retainers Cat 3658 Cams 830cc injs. Treadstone Cast SS manifold and Garrett 3582r .63 hotside,(has 3076 comp. housing to clear frame) full street boost (20psi) by ~4500rpm with a rev limit of 8500rpm Tune by Revo Tial 38mm WG AEB intake Manifold OBX BOV FMIC Meth inj.w/dual nozzles NEW less then 200 miles Southbend Custom 4 puck sprung hubbed clutch with an additional 800lbs of clamping force on the pressure plate and an 15 lb. steel flywheel. Return style fuel system with adj. FP regulator and Walbro 255hp pump 034 street motor and trans mounts with a Neuspeed snub JHM Short shifter Shutt sport steering wheel 116k miles on body Black leather Heated seats The body is silver in excellent condition This car makes over 400 hp Over $12000 in parts The bad Fuel pump went bad 2 weeks ago so the car does not start! Call me at 914 482 0398
Lo-Fi Version | Time is now: 3rd June 2024 - 06:57 AM |
