> 914World Classifieds Rules
> FS: Uber Rare 914-6 Rear Calipers, CSOB's cover your eyes...
Eric_Shea
post Nov 16 2011, 10:54 PM
PMB Performance
For sale is a pair of rare 914-6 calipers completely restored to their preeminent glory.
For those looking these days, it was probably six months before I stumbled upon these. They have become rarer than hens teeth as of late. What you get with a 914-6 caliper is:
* A slightly larger caliper that bolts on to any standard 914 rear arm.
* A larger 911 rear pad size.
* A pair of larger 38mm pistons (again, same as the 911 rear through 1983).
* A caliper that will allow you to run a larger front caliper and retain proper brake bias.
* A caliper that can easily be spaced to become the uber, uber rare 914-6/GT caliper... all with factory parts (inquire within).
* A caliper that uses stock handbrake cables.
* A true solution for those who want a little more brake in their 914.
As mentioned above, these have become quite rare lately. Part of the reason is the Ferrari rear caliper market has gone through the roof as well, dragging this caliper along with it. If you've been wanting a pair for your project or, or your original 6 calipers have gone missing... these are for you. Asking $1,595.00 plus $10.50 shipping to U.S. destinations. $26.55 shipping to Canad and Mexico. $43.23 to Europe and Asia.
Replies(1 - 19)
ewdysar
post Nov 17 2011, 01:51 AM
What happens here, stays here.
A month ago, I would have grabbed these in a heartbeat. Eric's got all of my new brakes at his shop right now.
If you've been looking for them, you know that this is a good price. Don't let this opportunity pass you by...
BajaXJ92
post Nov 17 2011, 05:40 AM
Extended Member
(IMG:style_emoticons/default/drooley.gif)
Cairo94507
post Nov 17 2011, 08:13 AM
Michael
Hey, those look just like mine only a little different....
Mine seem to be a little wider. Seriously, Eric is the man when it comes to brakes. I love looking at these and will hate to bolt them up when the times comes but bolt them up I will. I am pleased to have these beautiful parts for my car.
URY914
post Nov 17 2011, 09:14 AM
That's real gold, right? (IMG:style_emoticons/default/biggrin.gif)
sean_v8_914
post Nov 17 2011, 10:35 AM
Chingon 601
I will have a set in my hands soon, right? when it happens, I will close the shop, draw the curtains and have a private moment with them alone. then I will put them on another man's car, take pictures and dream of calipers gone away (IMG:style_emoticons/default/sad.gif)
Eric_Shea
post Nov 17 2011, 12:27 PM
PMB Performance
Soon is a relative time frame (IMG:style_emoticons/default/biggrin.gif). They are at the machine shop now getting the bleeder mod. done (Ferrari calipers). When they get back they get plating and will be lovingly assembled by my tender falanges.
Eric_Shea
post Nov 17 2011, 12:33 PM
PMB Performance
Yes. Which makes them entirely too heavy for your car. Might I suggest something a little lighter and more cost effective?
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.bike-riding-guide.com-1110-1321554785.1.jpg)
They're "all-the-rave" in Canada right now.
eric9144
post Nov 17 2011, 12:39 PM
If you've been wanting to do this upgrade then you should totally jump on this deal!
sean_v8_914 I can make that 'fantasy' happen and might if I can't get my project rolling soon...just be gentle with them and clean 'em off before they go on (IMG:style_emoticons/default/biggrin.gif)
Luke M
post Nov 17 2011, 12:53 PM
Hey Eric,
I got a set of 914-6 calipers waiting to come off my six. How much to rebuild them to 914-6 Gt specs? I have a set of rear 911 M calipers that the hardware could be used from. Or I may just sell them and upgrade to Boxster rear calipers.
stugray
post Nov 17 2011, 02:02 PM
Eric,
Very interesting.....
When I purchased my 914, I got a box of calipers.
One pair of fronts look as nice as that set, but have 38mm pistons in them.
I assumed that they were from a 911 and the PO was going to upgrade.
Perhaps I was wrong.....
Any distinguishing numbers or ways to identify them as 911 or 914-6?
I will send pictures once i get home.
I sent the pics to you once before, but the quality was poor.
Stu
PeeGreen 914
post Nov 17 2011, 05:19 PM
QUOTE(Eric_Shea @ Nov 17 2011, 10:33 AM) *
After seeing this picture I outfitted all four corners with this system. I ended up crashing at the first stop and will be having my lawyers contact you ASAP (IMG:style_emoticons/default/poke.gif)
(IMG:style_emoticons/default/av-943.gif)
ewdysar
post Nov 17 2011, 05:51 PM
QUOTE(PeeGreen 914 @ Nov 17 2011, 03:19 PM) *
Apparently you did not adjust the pad clearances correctly, so I would have to say that this was an installation/operator error. Given that, I don't think that Mr Shea is liable..... (IMG:style_emoticons/default/biggrin.gif)
Eric_Shea
post Nov 17 2011, 06:03 PM
PMB Performance
(us E's have to stick together)
IronHillRestorations
post Nov 17 2011, 06:16 PM
I. I. R. C.
It's not Mr Shea's fault you can't squeeze hard enough.
ewdysar
post Nov 17 2011, 06:24 PM
QUOTE(stugray @ Nov 17 2011, 12:02 PM) *
Eric,
Stu
If your loose calipers have 38mm pistons, they are most likely 911 rears, probably M calipers.
The stock 914 calipers had 42mm pistons in the front and 33mm pistons in the back. The piston areas were 1385 sq mm and 855 sq mm respectively. This gave the brakes a natural 61/39 bias towards the front brakes, that's 56% more power to the fronts than the backs.
The 914/6 and 911s had 48mm fronts and 38mm backs with areas of 1809 sq mm and 1134 sq mm. That worked out to a natural 61/39 bias towards the front brakes, weird huh. (IMG:style_emoticons/default/idea.gif)
If you use 48mm fronts (911) with 33mm backs (stock 914) your brake bias shifts to 68/32 which puts 112% more stopping power to the fronts compared to the backs. That makes the rears largely ineffective. This matches what 914 owners have observed ever since they started upgrading their brakes.
So if you want to use the better 911 48mm front brakes, your best bet is to find 38mm rears. If you want to retain your stock e-brake setup, that narrows your choices to 914-6 (non-vented) or 914-6GT (vented). You can also do slight modifications to Ferrari 308 rears (also vented) and they'll work the same. The regular 914-6 calipers can be spaced for vented rotors
The problem is that all of these 38mm rear calipers with cable e-brakes are almost impossible to find. But wait, there is beautifully restored set available right now, right in this thread.
So if you're thinking about 911 fronts, well balanced brakes and keeping your 914 style e-brake, now is your chance. These opportunities only come up a couple of times a year.
Krieger
post Nov 17 2011, 07:31 PM
Act now... supplies are limted. If you call our 800 number in the next hour Eric will include two sham-wows. (IMG:style_emoticons/default/beer3.gif)
URY914
post Nov 17 2011, 07:40 PM
QUOTE(Eric_Shea @ Nov 17 2011, 11:33 AM) *
You're about 3 years too late, Grasshopper. I've been running those on all 4 corners for 3 years now. (IMG:style_emoticons/default/rolleyes.gif)
Eric_Shea
post Nov 17 2011, 07:50 PM
PMB Performance
Damn Eric... You're hired!
post Nov 17 2011, 10:29 PM
QUOTE(Luke M @ Nov 17 2011, 10:53 AM) *
Hey Eric,
Great question...whats the 'cost' to redo a set of -6 rears?
- Lo-Fi Version Time is now: 9th May 2025 - 06:21 AM
