| Krieger |
Nov 17 2011, 09:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,841 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Original tank with no way to drain except remove hose. I am going to be making new oil lines. I saw one of our guys that has put a "T" with a cap in line with the oil cooler. Has anyone added a drain plug to the tank? Tank is out of car now.
| sixnotfour |
Nov 17 2011, 09:21 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,153 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Might as well add a level sender too.
it is not that easy to access the bottom of the tank behind the rocker. IMO |
| Krieger |
Nov 17 2011, 09:29 PM
Yea, it is kinda tite.
| Krieger |
Nov 17 2011, 09:31 PM
This is the best I've seen so far. Somebody on this site had posted this a while ago.
| GeorgeRud |
Nov 17 2011, 10:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I think that this is the reason that the original -6 configuration has a coupling to drain the tank.
It would be very hard to access a drain in the bottom of the tank as it's positioned in the fender well. |
| Steve |
Nov 17 2011, 10:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,025 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I also used an AN16 T on mine. I love his bracket though. I need to find a better way to fasten down my T. It moves around to much when I take the cap on and off. I also saw another post a while back of someone that used JB weld to install a quick drain in there T.
| mskala |
Nov 18 2011, 02:53 PM
R ![]() ![]() ![]() Group: Members Posts: 1,935 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
I know a lot of people convert to -AN.
But I bought new lines from Patrick Motorsports last year, they are the old style except that both ends of the lines are same. So they give you a coupler. See it in this pic. So, if a coupler like that was available in a 'T' we would be all set for draining. Anyone see anything like that? Some would say just separate the lines with the big wrenches for oil changes and keep it simple. But I have a 4-post lift and using large wrenches right there really sucks. |
| Scott S |
Nov 18 2011, 03:58 PM
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
I bought the same two factory style lines from Rich Johnson. We'll see how oil the oil changes go. I did cut out a replica of the factory hook that I will be welding on. Not sure if that extra support makes any difference....
| mepstein |
Nov 18 2011, 04:07 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,532 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I bought the same two factory style lines from Rich Johnson. We'll see how oil the oil changes go. I did cut out a replica of the factory hook that I will be welding on. Not sure if that extra support makes any difference.... Scotty B is putting a replica hook on mine. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 11th March 2026 - 09:16 AM |
