OT - keys locked in car, 2005 VW beetle |
mepstein |
Nov 21 2011, 09:11 AM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
My son locked the keys in his beetle. VW charges $100 for a valet key and must be ordered. Any ideas from the collective?
VaccaRabite |
Nov 21 2011, 09:13 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Call a locksmith.
They will be able to get in (will set off the alarm) but you can get your car open for about $50. |
shuie |
Nov 21 2011, 09:15 AM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
AAA Family membership.
VaccaRabite |
Also, unless the key is chipped, find a VW key blank on ebay and take it to True Value to be cut. If the key is chipped I am sure there are instructions in the manual or on the web for programming the car to accept the chip - just like you can do with remote fobs.
Zach |
rohar |
Nov 21 2011, 09:30 AM
Senior Member Group: Members Posts: 924 Joined: 25-October 08 From: spokane Member No.: 9,685 Region Association: None |
Also, unless the key is chipped, find a VW key blank on ebay and take it to True Value to be cut. If the key is chipped I am sure there are instructions in the manual or on the web for programming the car to accept the chip - just like you can do with remote fobs. Zach The Ace down the street from my house does chipkeys now and stocks VW/Audi. Like $30 if I remember right. |
gendent |
Member Group: Members Posts: 89 Joined: 30-March 10 From: Lewison ID Member No.: 11,528 Region Association: Pacific Northwest |
Funny thing, this just happened to me on my way home. Stopped to scrape ice off window and locked keys in the car, with it running in a bad snow storm. 10 minutes later a guy comes by and helps, this is what he did: clipped about 3 feet of stiff fence wire, worked it down between door sill and gasket, and pushed the unlock button inside the car. I'm in. $50.00 dollars less and forever grateful for him coming by.
mepstein |
Nov 21 2011, 10:23 AM
my local mechanic said he's drop by and try - n/c. if he can't do it, on to plan B. probably a locksmith. I don't need another key, just a smarter son. (IMG:style_emoticons/default/dry.gif)
I love the old cars with cheap keys. I once had a jeep and my wife had a neon and one key would open both cars. |
tradisrad |
Nov 21 2011, 11:12 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
The best thing I ever put on my car is a hide-a-key!
Valy |
Nov 21 2011, 11:46 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Also, unless the key is chipped, find a VW key blank on ebay and take it to True Value to be cut. If the key is chipped I am sure there are instructions in the manual or on the web for programming the car to accept the chip - just like you can do with remote fobs. Zach I think you don't need the chip to open the door, you need it just to start the car. So a cheap copy of the key will open the door. |
mepstein |
Nov 21 2011, 12:12 PM
Also, unless the key is chipped, find a VW key blank on ebay and take it to True Value to be cut. If the key is chipped I am sure there are instructions in the manual or on the web for programming the car to accept the chip - just like you can do with remote fobs. Zach I think you don't need the chip to open the door, you need it just to start the car. So a cheap copy of the key will open the door. The cheap -"valet key" is $100 and has to be sent away to get cut. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) |
Rex-n-effect |
Nov 21 2011, 01:24 PM
Newbie Group: Members Posts: 44 Joined: 4-February 11 From: Missoula, MT Member No.: 12,659 Region Association: None |
Actually the key is $55.00 part# 3B0 837 219BB INB. Your local VW dealership orders this and gets it next day with no freight charge. The key has to be programmed to start and run the car. It will open the door and start the car but it will die after 3 seconds. This is the basic key not the switch blade style and remote.
Tom_T |
Nov 21 2011, 01:49 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Ray,
If it's an old beetle with the operable vent windows, then you can get in with a coat hanger & open the vent wing or unlock the opposite door with the long hanger fully unfolded - but you may bugger the seal a bit where you go in with the hanger. Don't know what the availability is on those seals today, but the locksmith may be less, & AAA member lock-service is the best deal! We had to do that several times on my HS buddy's 66 Ghia, when he lost his key off his swim trunk's drawstring while bodysurfing at the beach back in the day. No hope of finding the sucker in the sand/water, needed to get home - so go find a hanger & do it - but VW seal parts were cheaper then! After the second time, he got a hide-a-key! (IMG:style_emoticons/default/biggrin.gif) |
mepstein |
Nov 21 2011, 04:59 PM
my mechanic drove by and opened the car. no problem, no charge. (IMG:style_emoticons/default/biggrin.gif)
mepstein |
Nov 21 2011, 05:00 PM
Ray, If it's an old beetle with the operable vent windows, then you can get in with a coat hanger & open the vent wing or unlock the opposite door with the long hanger fully unfolded - but you may bugger the seal a bit where you go in with the hanger. Don't know what the availability is on those seals today, but the locksmith may be less, & AAA member lock-service is the best deal! We had to do that several times on my HS buddy's 66 Ghia, when he lost his key off his swim trunk's drawstring while bodysurfing at the beach back in the day. No hope of finding the sucker in the sand/water, needed to get home - so go find a hanger & do it - but VW seal parts were cheaper then! After the second time, he got a hide-a-key! (IMG:style_emoticons/default/biggrin.gif) 2005 |
mepstein |
Nov 21 2011, 05:02 PM
Actually the key is $55.00 part# 3B0 837 219BB INB. Your local VW dealership orders this and gets it next day with no freight charge. The key has to be programmed to start and run the car. It will open the door and start the car but it will die after 3 seconds. This is the basic key not the switch blade style and remote. Dealer wanted 100 for the cheapie basic key. I didn't buy the car and I never go there. Never will. |
Jeffs9146 |
Feb 25 2012, 01:07 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Hi I think should call to a good .... They will definitely solve this problem. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) My guess is he figured it out already! |
mepstein |
Feb 25 2012, 08:41 AM
My local mechanic stopped by and opened it for me. No charge.
Lo-Fi Version | Time is now: 10th June 2024 - 06:36 AM |
