malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Where would we be without great craftsmen? 1.8 heads with new 2.0 sized valves, 1.7 rockers and swivel adjusting screws for my soon to be 1911 cc fuel injected 75.
I love stickers! ![]() Nice thick valve seat! ![]() 53 CC should give me 8:1 ![]() I hate it that I am going out of town for Turkey Day. I could be working! ![]() |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
That right plug hole in the last picture looks eaten a bit.
And why the SS exhaust valves? The sodium filled are still available and not so expensive/ |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I wouldn't be surprised if Len added a notch for a CHT sensor ring.
And most builders are using SS valves. But Len would have to explain his own reasoning. That I'm not sure on. |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
The sodium filled are still available and not so expensive/ They are after one fails and takes out the entire engine. Been there, done that and added the ten thousand dollars worth of broken parts to my trophy shelf. When a sodium filled valve fails, it doesn't break.. It explodes. Heads look great to be nearly 4 decades old.. Len does awesome work. Hell, they look a lot better than the heads that I normally see pics posted of here that have visible cracks in the combustion chambers as their owners brag about the work that was done... Want perfection? Start with a brand new casting, otherwise you are always going to have some compromise. Len made these look great and the right spark plug hole has been modified for a CHT sensor as Mark stated.. Without that, life is hell. This post has been edited by Jake Raby: Nov 21 2011, 10:07 PM |
malcolm2 |
That right plug hole in the last picture looks eaten a bit. And why the SS exhaust valves? The sodium filled are still available and not so expensive/ He welded everything closed, then tapped new. You might just be seeing some exterior weld. the right plug you refer to is the notch for the CHT. |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,339 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
malcolm2 |
Len would have to explain his own reasoning. I asked Len to "do his thing". I trusted him to supply the best. I was completely ignorant to what should or could be done. I have not taken a VW engine apart in 20 years. He gave me some options, and you see the result. I look forward to getting this thing put back together and running. |
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
Glad you're happy with them Clark. they came out very nice.
QUOTE That right plug hole in the last picture looks eaten a bit. That's where I tied the weld into the casting. It bubbled a bit from oxidation. If it had been a critical surface I would have cut it out and rewelded. Since it's just the exterior around the CHT probe notch I let it ride. QUOTE And why the SS exhaust valves? The sodium filled are still available and not so expensive/ Definitely not a fan of them either. Thank goodness for modern (late 20th century) valve technology so we have alternatives. Admittedly the sodium filled do seem to hold up okay when new and with only so many miles of not so sprited driving, but at some point when they go, they go ugly! On the other-hand the SS just keeps on rolling along. I have NEVER seen one break without first colliding with a piston. Hope your build goes together smoothly and you're happy with your new engine Clark. |
Lo-Fi Version | Time is now: 18th September 2025 - 06:00 PM |
