> Fuel pump issue was working now it's not, Problem solved!
rick 918-S
post Nov 23 2011, 11:14 PM
Hey nice rack! -Celette
So I just started Sandy's 73 2.0 with F.I.
I relocated the pump to the front. The car started right up the first time we tried it.
After a couple good starts the fuel pump stopped working.
I checked the relay board and have power to terminal 30. I jumped the board to terminal 87 and got the pump to run but then the car still wouldn't start.
I checked for spark and that is working and good.
I swapped relays, no joy,
Any ideas?
Replies(1 - 14)
r_towle
post Nov 24 2011, 08:38 AM
Custom Member
Turn key on, do you hear it?
Turn headlights on...do they open up?
Take the relay from the headlight and use it at the fuel pump.
Check all your fuses,,,under the dash and in the relay board.
Rich
post Nov 24 2011, 09:05 AM
(IMG:style_emoticons/default/bye1.gif) Hey Rick, Happy Thanksxgiving. Does the pump have a good ground? Are you getting power to the pump? Crimped or crossed fuel line? Any fuel pressure?
rick 918-S
post Nov 24 2011, 10:09 AM
QUOTE(r_towle @ Nov 24 2011, 08:38 AM) *
Rich
First, there is no gas tank yet. I used a gas can set in the gas tank location with both fuel lines stuffed in the can.
No heads, motors or anything up front yet. Still disassembled.
I swapped 4 relays in place of the fuel pump relay, turned the to the on position and no joy. I understand the pump should run for a couple seconds.
Question, If I jump the relay pin 30 to 78 and get the pump to run could I still have a bad fuse on the fuse panel in the car?
I did not check that. I did check the fuse on the relay board and it is good.
rick 918-S
post Nov 24 2011, 10:11 AM
QUOTE(76-914 @ Nov 24 2011, 09:05 AM) *
Hi ya Ken! Happy T-Day! Fuel lines are not pinched under the air box... (IMG:style_emoticons/default/lol-2.gif) I know not funny then but....
post Nov 24 2011, 10:44 AM
QUOTE(rick 918-S @ Nov 24 2011, 08:11 AM) *
You steal one damned chicken and what happens? Everybody calls you a chicken thief. (IMG:style_emoticons/default/chair.gif) You still haven't said what your fuel pressure is....... Don't know = extra variables
rick 918-S
post Nov 24 2011, 11:13 AM
QUOTE(76-914 @ Nov 24 2011, 10:44 AM) *
I don't know but when the pump was running the engine started and ran. I haven't had it running long enough to get a gauge on it.
rick 918-S
post Nov 24 2011, 12:37 PM
Ok, I'm tracking down the problem. I have power to terminal 30. The ground terminal 85 is good. But I have no power coming from the wire marked III.
Q). Where does this wire come from? The ECU?
If that's the case this may explain why the engine won't start when the pump jumper is connected.
Any idea where the fault is?
jim912928
post Nov 24 2011, 01:35 PM
Rick....if you find the relay board to be bad I still have the one that was in my car before my conversion.
rick 918-S
post Nov 24 2011, 01:46 PM
QUOTE(jim912928 @ Nov 24 2011, 01:35 PM) *
Thanks Jim. I'm staring at the diagrams now trying to track down the issue. We shall see.
ejm
post Nov 24 2011, 02:29 PM
I can see the light at the end of the tunnel
QUOTE(rick 918-S @ Nov 24 2011, 01:37 PM) *
That wire is grounded thru the ecu to close the relay. Call me....
rick 918-S
post Nov 24 2011, 04:11 PM
QUOTE(ejm @ Nov 24 2011, 02:29 PM) *
Thanks for the help Ed! (IMG:style_emoticons/default/aktion035.gif) Ed had me perform a couple tests that eventually led to the conclusion that I was swapping bad relays around. (IMG:style_emoticons/default/slap.gif)
I'm heading over to the local flaps tomorrow and get some new ones.
r_towle
post Nov 24 2011, 05:13 PM
Custom Member
Headlight relays from the alien....
rick 918-S
post Nov 24 2011, 06:18 PM
QUOTE(r_towle @ Nov 24 2011, 05:13 PM) *
How'd you know... (IMG:style_emoticons/default/unsure.gif)
r_towle
post Nov 24 2011, 08:22 PM
Custom Member
It was my next suggestion....you need to know....then test.
- Lo-Fi Version Time is now: 6th June 2026 - 03:13 PM
