> Is there a diagram or photo someplace with the late style Blower motor?
rick 918-S
post Nov 25 2011, 02:30 AM
Hey nice rack! -Celette
I am looking for a exploded view or diagram or photo of the late style blower motor and the connections.
I have a 73 2.0. The blower motor is located on the left side of the engine bay. It have one outlet unlike the early blower with two outlests.
I have a plastic tube that I believe connects the blower to the left side "J" tube.
Problem is I have a right side "J" tube that has nothing connected to it. What feeds the right side "J" tube on the later model cars?
Replies(1 - 19)
McMark
post Nov 25 2011, 03:17 AM
914 Freak!
73/74 cars just capped off the J-tube because you would still get hot air on the passenger side because of the air from the cooling fan that is route through the system. 75/76 cars had a nozzle/splitter that hooked up to both sides. The nozzle can be retrofitted to an earlier blower.
The 70/72 blower mounted on the engine and is a different setup that had dual outlets.
jimkelly
post Nov 25 2011, 06:58 AM
Delaware USA
http://www.autoatlanta.com/porsche-parts/p...e_914_parts.php
heater fan
blower motor
Gint
post Nov 25 2011, 08:42 AM
Mike Ginter
Those electric blower motors are more trouble than they're worth IMO. I just cap both holes. They only put out weak air flow at and just above idle. Above 2k rpm the cooling fan overcomes the volume of air that the electric motor provides anyway.
shulew 3
post Nov 25 2011, 09:14 AM
desert toy
QUOTE(rick 918-S @ Nov 25 2011, 12:30 AM) *
There is a splitter available from AA that will give you warm air on both sides using the fan(red knob) Works fine
part # BMIS400 heater blower upgrade kit 914 1970-76 $38.50 (was that in '09)
Lew
rick 918-S
post Nov 25 2011, 09:22 AM
I would be happy with the cap method Mark mentioned. Anyone have a photo of the cap? I have never even seen one.
dlee6204
post Nov 25 2011, 09:46 AM
Howdy
A photo of said cap...
Rick, if you want it, its yours.
GaroldShaffer
post Nov 25 2011, 09:49 AM
You bought another 914?
QUOTE(Gint @ Nov 25 2011, 06:42 AM) *
(IMG:style_emoticons/default/agree.gif) with Gint. My 70 doesn't have the fan blower installed. As long as I am moving there is more than enough airflow to move heat into the car. Heck even at idle I have warm air coming when I open the flappers.
Gint
post Nov 25 2011, 09:58 AM
Mike Ginter
Tell me what you need Rick. I'm off to the Rod show.
gendent
post Nov 25 2011, 10:26 AM
An easy solution was provided for me at Home Despot, there are rubber plumbing caps that even come with clamps for under $5.00. It has worked well for me.
rick 918-S
post Nov 25 2011, 10:47 AM
Cool! The photo Doug provided and the Home Depot source suggestion will work great!
Mike I still need the right and left part #23 in the diagram for the early style H.E.'s. That will complete the heater for Sandy's car. We'll be driving this thing in the spring! (IMG:style_emoticons/default/driving-girl.gif)
Gint
post Nov 25 2011, 06:05 PM
Mike Ginter
23 is just flexible hose. I sent you a PM rick. I thought you needed 24 and 25.
tod914
post Nov 25 2011, 06:17 PM
You can still get the long hose from Porsche. It's cheap! The short, is cut down long hose now. Likely they ran out. So it will not have the flat edgeing. The hose clamps last time I checked, are NLA.. but Norma and other companies have substitutes. Post some shots! Anxious to see how it's turning out.
rick 918-S
post Nov 25 2011, 09:26 PM
QUOTE(Gint @ Nov 25 2011, 06:05 PM) *
Got the PM Mike. I'm a dork... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/biggrin.gif)
Here's what I need.
rick 918-S
post Nov 25 2011, 09:28 PM
QUOTE(tod914 @ Nov 25 2011, 06:17 PM) *
I'll update The build thread later tonight. It's really starting to look nice. Sandy is going to be pleased. (IMG:style_emoticons/default/driving-girl.gif)
Gint
post Nov 25 2011, 10:17 PM
Mike Ginter
I don't think I have any of those. I'll have to take another look tomorrow.
rick 918-S
post Nov 25 2011, 10:48 PM
QUOTE(Gint @ Nov 25 2011, 10:17 PM) *
Thanks. Shoe thought he may have some. I sent him a photo.
McMark
post Nov 27 2011, 09:36 PM
914 Freak!
If you can't find any I know I have a box. (IMG:style_emoticons/default/wink.gif)
partwerks
post Nov 27 2011, 09:52 PM
That squirrel cage blower would suck in cold air and introduce that into the system, which didn't really help matters any. A person should rig up something where it would at least draw in some warm air off the engine once it gets warmed up to circulate it back into the system.
bigkensteele
post Nov 27 2011, 11:20 PM
Major Member
QUOTE(partwerks @ Nov 27 2011, 07:52 PM) *
If everything is in working order and not leaking more than it did from the factory, the 914 cabin heating will roast you, even in Duluth.
I just put mine back together, but I back-dated my exhaust from a '75 1.8 to a '73/74 2.0 with SSIs. The heater cables aren't quite long enough now, so both flapper boxes are partially open, the passenger side the most.
It was 55 here yesterday. I took it for a drive with the top off but the windows up, and I came back almost sweating.
My next project is to install a console. Therefore, the cables must come out, so this problem will be resolved.
- Lo-Fi Version Time is now: 31st July 2025 - 09:25 AM
