| EdwardBlume |
Nov 25 2011, 06:22 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I broke the seal from the crank and it broke everything loose except the dowel underneath the oil cooler on the lower side of the engine.
How do I pull this area apart? |
| VaccaRabite |
Nov 25 2011, 06:48 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,841 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Find the bolt you missed.
Zach |
| EdwardBlume |
Nov 25 2011, 07:06 PM
Didn't miss any.... unless there's one inside the oil pressure sender.
| EdwardBlume |
Nov 25 2011, 07:16 PM
Here's a bloody pict....
Attached thumbnail(s) |
| EdwardBlume |
Nov 25 2011, 07:18 PM
Everything is free except the 90 deg underneath the oil cooler....
This is an original never been split since new case.... but there are a couple love taps on the case when it was nudged in during assembly... Attached thumbnail(s) |
| bigkensteele |
Nov 25 2011, 07:29 PM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
Isn't there one around the oil filler console that is easy to miss? Might be inside...
| EdwardBlume |
Nov 25 2011, 07:35 PM
Isn't there one around the oil filler console that is easy to miss? Might be inside... Thanks. Both 10MM nuts are off around the oil filler rectangle. Like I said, everything is free with 1-3 mm of free play less this one 4-6 inch elbow. I need a strong but gentle man to pull from the other side... |
| Van |
Nov 25 2011, 07:58 PM
Member ![]() ![]() Group: Members Posts: 199 Joined: 15-January 08 From: Hyde Park, NY Member No.: 8,571 |
Probably dealing with some corrosion on a dowel pin... Be stronger with your "love taps".
| a914dude |
Nov 25 2011, 08:06 PM
Wanker ![]() ![]() Group: Members Posts: 247 Joined: 18-September 10 From: Saskatoon Member No.: 12,191 Region Association: Rocky Mountains |
Count yer nutz. (IMG:style_emoticons/default/dry.gif)
| EdwardBlume |
Nov 25 2011, 08:20 PM
"testes.. one, two... THREE?" -Beavis |
| EdwardBlume |
Nov 25 2011, 08:33 PM
| Mark Henry |
Nov 26 2011, 08:46 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Is there still a couple of washers on the studs? They can hang up on the threads.
| JStroud |
Nov 26 2011, 09:18 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
It could be sealant holding it together there, I had to be pretty aggressive with a rubber mallet to break mine free, even after all the bolt were out.
If you have a plastic sliding squeeze clamp you can flip it around and make it a spreader, put it in the oil pump hole, spread there while using the rubber mallet. Good luck, oh and nice cars, Jeff |
| EdwardBlume |
Nov 26 2011, 09:34 AM
Got it.
I carefully took a straight edge piece of wood and carefully tapped it out with a rubber mallet. The flange sticking up was "practically there for it." |
| Randal |
Nov 26 2011, 10:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Nice video Rob. You just need to add music. |
| Jake Raby |
Nov 26 2011, 03:04 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
After watching the video I'll say that you just need to get more aggressive.. I believe the case dowel does have it caught at that area... Use a pair of screwdrivers VERY CAREFULLY on both sides of the area that won't separate and try to spread it open with them both simultaneously.
OR use the screwdriver to load the area up and then carefully chatter against the dowel area with an air hammer and it will probably split right away... A dead blow or rubber mallet probably isn't going to do it, not enough concentrated shock load at the dowel area from those wimpy devices.. Use common sense, but grow a pair because thats the only thing thats going to get it apart. Splitting a case is easy, I have had this happen to me on a couple of occasions but generally they fall apart and they should. Clean that dowel and it's bore really well before reassembly. |
Lo-Fi Version | Time is now: 15th March 2026 - 04:25 PM |
