> Its been wayyyyy to long man., ...car won't start.
oldschool
post Nov 29 2011, 12:19 AM
...Its been a very busy summer/Year and haven't much time to cruz the site and now winter is here, But now for the real story, My car is having a bad day...it won't start.
It started running bad ..So I gave it a Mexican tune-up, points,cap,etc..
took it out for a (IMG:style_emoticons/default/driving.gif) and about a mile down the road, She just stop.
So today I try starting her up again.. (IMG:style_emoticons/default/headbang.gif) ..nothing.
I have spark at the dist. Now I'm checking the relays (IMG:style_emoticons/default/confused24.gif) ....I was thinking of going point-less HELP..please.
Replies(1 - 14)
silver74insocal
post Nov 29 2011, 12:27 AM
whats the fuel situation?
Mike Bellis
Resident Electrician
Clogged injectors from sitting with crappy gas?
oldschool
post Nov 29 2011, 01:14 AM
QUOTE(silver74insocal @ Nov 28 2011, 10:27 PM) *
? never had a problem...Its been running since I got her.
oldschool
post Nov 29 2011, 01:15 AM
QUOTE(kg6dxn @ Nov 28 2011, 10:27 PM) *
I was driver her almost every week end...No bad Gas.
silver74insocal
post Nov 29 2011, 01:24 AM
if it will fire on starter fluid you've got a fuel delivery problem. use that stuff sparingly though. if not double check your spark (IMG:style_emoticons/default/beerchug.gif) Dave
einic
post Nov 29 2011, 03:45 AM
Check the fuse for the fuel pump in engine compartment, connections on the pump. You should hear the pump turning when you turn on the ignition. (Few seconds)
KELTY360
post Nov 29 2011, 08:08 AM
914 Neferati
I think you're on the right track to check the relays.
rick 918-S
post Nov 29 2011, 08:14 AM
Hey nice rack! -Celette
Just went through a no start issue. Turned out to be a bad relay. I spent a day swapping in bad ones that I thought were good. (IMG:style_emoticons/default/wacko.gif) As suggested, if it will fire on starting fluid it's a fuel issue.
r_towle
post Nov 29 2011, 11:20 AM
Custom Member
do the headlights pop up and down?
If so, take one of those relays (that you know work by testing your headlights) and replace the fuel pump relay with one.
Rich
Series9
post Dec 1 2011, 09:42 AM
Lesbians taste like chicken.
QUOTE(r_towle @ Nov 29 2011, 12:20 PM) *
Rich
oldschool
post Dec 1 2011, 12:07 PM
QUOTE(rick 918-S @ Nov 29 2011, 06:14 AM) *
Is there a way to check the relays? with a meter maybe, if so that should they read?
r_towle
post Dec 1 2011, 12:12 PM
Custom Member
sort of....
Relays are switches.
two poles are switched on and off to carry current.
One of the other poles is the actual switch...so if you engergize it, you will close the switch.
So, you can test them, but you will need 12vdc and ground.
Rich
oldschool
post Dec 1 2011, 12:15 PM
QUOTE(r_towle @ Dec 1 2011, 10:12 AM) *
sort of....
Rich
Got it, should I hear the pump when I insert the good relay...if I have the switch on?
oldschool
post Dec 9 2011, 02:30 AM
Rick I had my old friend (BR)come over to help with the car......it was the connection to the fuel pump.....I still need to fix the wire that came /broke off but it should be up and running this weekend (IMG:style_emoticons/default/piratenanner.gif)
- Lo-Fi Version Time is now: 12th July 2025 - 10:54 AM
