alternator boot |
alternator boot |
mrbubblehead |
Dec 5 2011, 09:38 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
does anyone know where i can get the D shaped alternator boot? the tube that supplies cool air to the alternator. i need to replace my alternator and chances are mine will be jacked.
mrbubblehead |
Dec 5 2011, 09:52 PM
bigkensteele |
Dec 5 2011, 09:55 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
It will probably be fine, given that it is most likely covered in oil/sludge, and it probably hasn't seen sunlight in 40 years. Mine was still pretty soft.
If you need to remove it, don't forget the c-clip on the inside of the fan housing (ask me how I know). You don't need to split the housing to remove or install it, but you will need to pull the fan to get to it with some long pliers. I had my engine all the way back together and had that clip left over. Could not think of where it went, but the board rescued me! |
mrbubblehead |
Dec 5 2011, 10:44 PM
oh really.... i thought it fit in like a grommet. sounds like a PIA. i ordered one just in case. i guess i'll find out as soon as i get the alternator out.
SLITS |
Dec 6 2011, 11:14 AM
No need to remove the boot from the fan housing .... you can disconnect it from the alternator.
bigkensteele |
Dec 6 2011, 11:19 AM
No need to remove the boot from the fan housing .... you can disconnect it from the alternator. (IMG:style_emoticons/default/agree.gif) I should have mentioned that. If you are just replacing your alternator, just loosen the clamp and the alternator will slide out. I was pulling everything apart and cleaning, so maybe a different situation. |
Lo-Fi Version | Time is now: 3rd June 2024 - 11:32 AM |
