F/S: Bolt-On 5-Lug Conversion Kit, SOLD!! |
BajaXJ92 |
Dec 6 2011, 07:53 AM
Extended Member Group: Members Posts: 2,146 Joined: 20-April 06 From: Prescott, AZ Member No.: 5,895 Region Association: MidAtlantic Region |
I originally purchased these parts from another member here back in June before my '71 got rear ended. I intended to use the spacers in the rear and rotors in the front as an easy 5-lug conversion. They're just sitting around and I figure another member could use them. (IMG:style_emoticons/default/smile.gif)
Everything you see pictured is what is for sale. For now, I prefer to sell everything together as a kit. (IMG:style_emoticons/default/smile.gif) $179.90 gets everything shipped to your door DOMESTIC in 2 Large USPS Flat Rate Boxes.($14.95/each) If you'd like to pick it up locally, $150 gets you this setup. -5 lug adapters. According to the member I bought them from, they only have about 5000 miles on them. These space the wheels out 1". I'm including the attachment lug bolts, AND a socket that he ground down to fit the counterbore to torque the bolts. -914/4 front rotors drilled and tapped for 5 lug. According to the member I bought them from, they have about 12,000 miles on them but there isn't even a ridge around the circumference of the rotor. Included are the front rotors, 10 screw-in studs (never used), bearings (untouched in the hub), and dust caps. If it's not in the photo, it isn't included. These could bolt on to your car in a couple of hours, as a used 5-lug setup, ready to go. This is a great package if you're on a budget. You could even use these bearings and old grease as is, but you really should repack them and replace the grease seals, duh. (IMG:style_emoticons/default/biggrin.gif) Any questions, PM me. (IMG:style_emoticons/default/smile.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/img39.imageshack.us-5895-1323179584.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img163.imageshack.us-5895-1323179584.2.jpg) |
BajaXJ92 |
Dec 10 2011, 09:49 AM
SOLD! (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 10th June 2024 - 08:14 PM |
