SHOCKING question |
SHOCKING question |
spare time toys |
Aug 16 2004, 10:58 AM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
Does any one know what brand of coil over I could have? The ones I have have the piston rod on the lower end with the coil, and the cylinder on the top. Thay have no marking on them but are chromed, big deal you cant see it unless you lay under the back of the car and look up. Most all the coil overs I have seen are piston rod up and coils on top. These just look wrong. (IMG:style_emoticons/default/confused24.gif)
ArtechnikA |
Aug 16 2004, 11:18 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(spare time toys @ Aug 16 2004, 08:58 AM) piston rod on the lower end with the coil, and the cylinder on the top. that -sounds- like a Bilstein (they're famous for the inverted reservoir implementation that gas-pressure makes possible...) but i've never seen an inverted damper for a 914, and i've never seen a chromed Bilstein. if the manufacturer's name isn't on the damper body somewhere, you probably don't want it in your car ... |
mike_the_man |
Aug 16 2004, 04:21 PM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Ya knew it was coming, didn't ya! |
spare time toys |
Aug 16 2004, 04:49 PM
QUOTE(mike_the_man @ Aug 16 2004, 02:21 PM) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Ya knew it was coming, didn't ya! Yes I know but my computer has some issues and does not like to work with me at this time. (IMG:style_emoticons/default/ar15.gif) I should go get a new one but the kids would mess it up also (IMG:style_emoticons/default/mad.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 03:04 AM |
