WTF? How can this happen., I need other sets of eyes on this. |
Series9 |
Dec 21 2011, 12:04 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Setting up Nelson's steering and find this. The shaft is too short.
How can that be? The suspension is all bolted up where it goes. Attached image(s) |
SirAndy |
Dec 21 2011, 12:05 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Setting up Nelson's steering and find this. The shaft is too short. How can that be? The suspension is all bolted up where it goes. It doesn't look like it's bolted up correctly. That rubber doughnut needs to come up much higher through that hole. Did you install rack spacers? Did you forget the rearward bolts on the tabs for the steering rack? They need to be seated correctly. (IMG:style_emoticons/default/idea.gif) |
SirAndy |
Dec 21 2011, 12:07 PM
How about a pic of the other side of things? (IMG:style_emoticons/default/idea.gif)
BajaXJ92 |
Dec 21 2011, 12:08 PM
Extended Member Group: Members Posts: 2,146 Joined: 20-April 06 From: Prescott, AZ Member No.: 5,895 Region Association: MidAtlantic Region |
The shaft is too short. (IMG:style_emoticons/default/blink.gif) Sorry to hear, Nelson. (IMG:style_emoticons/default/unsure.gif) |
ruby914 |
Dec 21 2011, 12:09 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
Is that shaft a different length on a 911 compared to a 914?
SirAndy |
Dec 21 2011, 12:16 PM
Is that shaft a different length on a 911 compared to a 914? Yes, it is. But that doesn't explain why the rubber doughnut does not come up far enough. (IMG:style_emoticons/default/popcorn[1].gif) |
Cap'n Krusty |
Well, it has a different part number, indicating there's a difference of some kind.
The Cap'n |
Series9 |
Dec 21 2011, 12:43 PM
I'm sure I'm going to feel stupid when someone points out what's wrong, but sometimes you can't see for forest for the trees.
These are the exact same parts that were removed from the car. The bolts in the rack are loose because I'm looking at this problem. Attached image(s) |
SirAndy |
Dec 21 2011, 12:54 PM
All the bolts need to be tight, including the two i marked in the pic.
(IMG:style_emoticons/default/popcorn[1].gif) Attached image(s) |
KELTY360 |
Dec 21 2011, 12:59 PM
914 Neferati Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Series9 |
Dec 21 2011, 01:16 PM
All the bolts need to be tight, including the two i marked in the pic. (IMG:style_emoticons/default/popcorn[1].gif) They were. I pulled them out to mess with it. Trust me, that's not it. But, just to be sure, I just put in all the bolts and tightened them up. No change. This thing is like 1.5" out of place. |
sixnotfour |
Dec 21 2011, 01:38 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
captn's right you have a 911 shaft.
ruby914 |
Dec 21 2011, 02:38 PM
How long is your shaft? (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/lol-2.gif)
montoya 73 2.0 |
Dec 21 2011, 02:45 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
The shaft is too short. (IMG:style_emoticons/default/blink.gif) Sorry to hear, Nelson. (IMG:style_emoticons/default/unsure.gif) This thread went bad in a hurry! (IMG:style_emoticons/default/biggrin.gif) |
Madswede |
Dec 21 2011, 05:59 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
The shaft is too short. (IMG:style_emoticons/default/blink.gif) Sorry to hear, Nelson. (IMG:style_emoticons/default/unsure.gif) Dayum. Just got (IMG:style_emoticons/default/owned.gif) (IMG:style_emoticons/default/dry.gif) I'll remember this when the car's done! (IMG:style_emoticons/default/ar15.gif) |
SLITS |
Dec 21 2011, 06:13 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
O'brien ... the bearing is in the correct location ... a plate goes over it. And inside that rubber you will find a caged roller bearing.
There is a length difference between the input shaft of a 911 and a 914 and I don't remember which one is shorter. I just use a 914 rack with the 911 suspension. |
Series9 |
Dec 21 2011, 06:48 PM
These are the parts that were driving this 914 when it arrived. I need a better explanation.
BMITCHELL |
Dec 21 2011, 06:55 PM
Member Group: Members Posts: 327 Joined: 28-February 05 From: Moorpark, CA Member No.: 3,681 |
Did you have another rack out from a 911 at the time? Parts get comingled?
jimkelly |
Dec 21 2011, 07:00 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
the answer is under the plastic cover : (
(IMG:http://www.914world.com/bbs2/uploads/post-3419-1315357690.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-3419-1315514194.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-3419-1319820864.jpg) |
ellisor3 |
Dec 21 2011, 07:12 PM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
Joe,
When I was there, I left you a steering rack I had left over from my project. Maybe they got mixed up. I am 99% certain it was a 914 rack though. |
Lo-Fi Version | Time is now: 7th June 2024 - 12:32 PM |
