Compufire ignition install, fitting issues with orig vac advance dissy. |
edwin |
Dec 27 2011, 02:42 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
Hi guys
Bought Dad a compufire ignition kit for his kombi (type 4 with 914 dissy) for christmas and have gone to install it tonight but am having issues getting everything sitting right. I know i am breaking all the rules by no adding photos but will have to charge my phone wich died while doing this. The compufire kits come as either vac advance or 009 mech advance and i bought the vac advance which my research shwoed was only different due to the small spacer in the kit. Without the spacer that slides on the dissy shaft the disc hits the sensor itself and with it on the rotor sits too high and the cap jams the shaft. Am wondering if there is something i am missing that others have found a solution to. Also the wires sit very close to the advance arm or the disc which seems to be bad design is this a problem? Thanks for all help in advance and i'll try and get some pics later Cheers Edwin |
Cupomeat |
Apr 25 2020, 02:39 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Hi guys Bought Dad a compufire ignition kit for his kombi (type 4 with 914 dissy) for christmas and have gone to install it tonight but am having issues getting everything sitting right. I know i am breaking all the rules by no adding photos but will have to charge my phone wich died while doing this. The compufire kits come as either vac advance or 009 mech advance and i bought the vac advance which my research shwoed was only different due to the small spacer in the kit. Without the spacer that slides on the dissy shaft the disc hits the sensor itself and with it on the rotor sits too high and the cap jams the shaft. Am wondering if there is something i am missing that others have found a solution to. Also the wires sit very close to the advance arm or the disc which seems to be bad design is this a problem? Thanks for all help in advance and i'll try and get some pics later Cheers Edwin Well, Search lead me to this post from 9+yrs ago. What did you end up doing? My issue is the rotor doesn't go down far enough to engage the keyway. I am thinking of sanding off the rotor bottom. THoughts? |
dr914@autoatlanta.com |
Apr 25 2020, 02:43 PM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yup sand it or buy a 311 rotor
Cupomeat |
Apr 27 2020, 07:46 PM
yup sand it or buy a 311 rotor Hi guys Bought Dad a compufire ignition kit for his kombi (type 4 with 914 dissy) for christmas and have gone to install it tonight but am having issues getting everything sitting right. I know i am breaking all the rules by no adding photos but will have to charge my phone wich died while doing this. The compufire kits come as either vac advance or 009 mech advance and i bought the vac advance which my research shwoed was only different due to the small spacer in the kit. Without the spacer that slides on the dissy shaft the disc hits the sensor itself and with it on the rotor sits too high and the cap jams the shaft. Am wondering if there is something i am missing that others have found a solution to. Also the wires sit very close to the advance arm or the disc which seems to be bad design is this a problem? Thanks for all help in advance and i'll try and get some pics later Cheers Edwin Well, Search lead me to this post from 9+yrs ago. What did you end up doing? My issue is the rotor doesn't go down far enough to engage the keyway. I am thinking of sanding off the rotor bottom. THoughts? Thanks!!! |
porschetub |
Apr 27 2020, 08:03 PM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
yup sand it or buy a 311 rotor Hi guys Bought Dad a compufire ignition kit for his kombi (type 4 with 914 dissy) for christmas and have gone to install it tonight but am having issues getting everything sitting right. I know i am breaking all the rules by no adding photos but will have to charge my phone wich died while doing this. The compufire kits come as either vac advance or 009 mech advance and i bought the vac advance which my research shwoed was only different due to the small spacer in the kit. Without the spacer that slides on the dissy shaft the disc hits the sensor itself and with it on the rotor sits too high and the cap jams the shaft. Am wondering if there is something i am missing that others have found a solution to. Also the wires sit very close to the advance arm or the disc which seems to be bad design is this a problem? Thanks for all help in advance and i'll try and get some pics later Cheers Edwin Well, Search lead me to this post from 9+yrs ago. What did you end up doing? My issue is the rotor doesn't go down far enough to engage the keyway. I am thinking of sanding off the rotor bottom. THoughts? Thanks!!! I totally disagree ,DO not sand the base of the rotor,the magnetic pick is simply not pushed on the driveshaft properly,jeez George you should no better ???. |
Cupomeat |
Apr 30 2020, 09:11 PM
yup sand it or buy a 311 rotor Hi guys Bought Dad a compufire ignition kit for his kombi (type 4 with 914 dissy) for christmas and have gone to install it tonight but am having issues getting everything sitting right. I know i am breaking all the rules by no adding photos but will have to charge my phone wich died while doing this. The compufire kits come as either vac advance or 009 mech advance and i bought the vac advance which my research shwoed was only different due to the small spacer in the kit. Without the spacer that slides on the dissy shaft the disc hits the sensor itself and with it on the rotor sits too high and the cap jams the shaft. Am wondering if there is something i am missing that others have found a solution to. Also the wires sit very close to the advance arm or the disc which seems to be bad design is this a problem? Thanks for all help in advance and i'll try and get some pics later Cheers Edwin Well, Search lead me to this post from 9+yrs ago. What did you end up doing? My issue is the rotor doesn't go down far enough to engage the keyway. I am thinking of sanding off the rotor bottom. THoughts? Thanks!!! I totally disagree ,DO not sand the base of the rotor,the magnetic pick is simply not pushed on the driveshaft properly,jeez George you should no better ???. I am not sure of that. The kit comes with a spacer to put below the magnetic puck disc and if I mount it without it, it intersects with the pickup module. It cannot go any lower on the Distributor shaft. |
michael7810 |
Apr 30 2020, 09:34 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I've installed dozens of compufires on VW engines and about half of them require sanding the bottom of the rotor to allow the cap to fit properly. A belt sander is what we use.
Lo-Fi Version | Time is now: 8th June 2024 - 01:01 AM |
