What's this thng for?, Flapper valve on intake horn |
Joe Ricard |
Aug 23 2004, 08:16 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Oil bath air cleaner. has this rectangle flapper that has a counter balance wieght on it. Seems from racing yesterday it was blocking off the PCV vent to the intake. Oil seemed to still find the path of least resistance and leaked out of the hose connected to the PCV and the cork gasket between the filler/breather box and case What a mess.
SLITS |
Aug 23 2004, 08:40 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
It 's to keep weak mice out of your intake. The stronger ones just push through.
or It's to keep the good air in and not let the bad air out or It creates turbulence in the incoming air or It's part of the archaic warm air system fitted to cars in very cold climates. or ??????????????? |
SirAndy |
Aug 23 2004, 08:48 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(SLITS @ Aug 23 2004, 07:40 PM) It's part of the archaic warm air system fitted to cars in very cold climates. bingo ... |
SLITS |
Aug 23 2004, 08:57 PM
QUOTE(SirAndy @ Aug 23 2004, 07:48 PM) QUOTE(SLITS @ Aug 23 2004, 07:40 PM) It's part of the archaic warm air system fitted to cars in very cold climates. bingo ... Ahh Andy, I liked the other answers better. Since you made me fess up, I'll explain the principle (IMG:style_emoticons/default/laugh.gif) On start up, the air velocity would be low, causing the flapper to stay in a closed position, thereby drawing warm air off the HEs. As the throttle is opened, the velocity of cold air overcomes the counterweight and restricts the flow of warm air. Then figuring in the density of warm air vs cold air.............., (IMG:style_emoticons/default/idea.gif) What do I win? |
Joe Ricard |
Aug 23 2004, 09:06 PM
You win another one of what ever you are smoking. (IMG:style_emoticons/default/idea.gif) Well since it made a mess it has to go. At least till I make a few redline runs to see what happens now. Pretty tough to do on the street. Matbe just leave it in 2nd all the way to work. Rise and shine all ya'll. BBWWWHHHAAAAAAAAA
SLITS |
Aug 23 2004, 09:16 PM
QUOTE(Joe Ricard @ Aug 23 2004, 08:06 PM) You win another one of what ever you are smoking. (IMG:style_emoticons/default/dry.gif) There is no provision for air to be taken in off the HE's. So Maybe it is a mouse preventer after all (IMG:style_emoticons/default/idea.gif) Well since it made a mess it has to go. At least till I make a few redline runs to see what happens now. Pretty tough to do on the street. Matbe just leave it in 2nd all the way to work. Rise and shine all ya'll. BBWWWHHHAAAAAAAAA On some cars, there was an elbow/j-tube coming off the HEs through the tin for that purpose. You can also check page 41 of your Haynes Manual (if you have one). I think I will have another (IMG:style_emoticons/default/smoke.gif) |
Joe Ricard |
Aug 24 2004, 10:48 AM
Well while you are at it give me one (IMG:style_emoticons/default/smoke.gif) Ya got a haynes and factory set of books. HMM maybe I should read it again????? Is it me or do the factory manuals jump all over the place concerning the obscure little things I can't figure for myself.
Didn't drive today as I decided to do a valve check and brake vent clearance without burning out of my arms. Got to get up under and clean oil soaked road grime too. (IMG:style_emoticons/default/wacko.gif) |
watsonrx13 |
Aug 24 2004, 05:23 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Joe, if it's for heat take it out, you got enough heat in MS already.... (IMG:style_emoticons/default/biggrin.gif)
Joe Ricard |
Aug 24 2004, 08:11 PM
Yea tell me about it. Never did stop sweating tonight. Just got the car put back in the garage. Set venting clearance rear brakes. Q: Why does this always seems to take so long. ans: Because it is hot never seen two car with same size inner screw. Can't see it so I ended up taking caliper off to get it right so I didn't strip anything. Actually these were all screwed up one pad loose one pad tight and dragging. (IMG:style_emoticons/default/idea.gif) same on the other side. (IMG:style_emoticons/default/blink.gif) Anyway it is time to watch hot chicks play beach volley ball.. Yes the USA girls are HOT. No need to vote that one
Lo-Fi Version | Time is now: 3rd June 2024 - 05:51 AM |
