> Original OEM 6 engine install question, Front bolt-is there a trick?
Krieger
post Dec 30 2011, 09:40 AM
I temporarily installed the engine in my car yesterday!. I am using a factory oem front mount. Everything lined up great, the bolt went in up through the engine bracket and rubber mount nicely. It was difficult to get the bolt threaded into the nut plate on top. The plate kept moving. The way everything was situated (on my low rise lift) I couldn't get a hand on top to hold it. Is there a trick to doing this? I'm thinking maybe of using some glue/seam sealer to hold it in place.
Replies(1 - 13)
GeorgeRud
post Dec 30 2011, 11:10 AM
Tie wrap around the mount?
sixnotfour
post Dec 30 2011, 01:09 PM
Does your bolt have the tapered end ?
Krieger
post Dec 30 2011, 04:10 PM
I like the tie wrap idea. I have to check next time I take the engine out if the boltis tapered.
iamchappy
post Dec 30 2011, 05:21 PM
It all happens so fast!
Are you sure you had it positioned right, it sort of sits in a cradle when it's aligned.
rgalla9146
post Dec 30 2011, 05:55 PM
QUOTE(Krieger @ Dec 30 2011, 02:10 PM) *
Is the transaxle raised all the way to its' mounts ? Don't even try until it is. Have a drift pin ? use that first to align the front mount
Use a 19mm short socket on a 10 " extension so that your hands are free of any interference. The two tangs on the nut plate allow enough play so that the bolt starts with no problem'
Also I've found it much easier to install a 6 engine without the two side tins installed.
Install them afterward, it 's a bit tight but very do-able.
Krieger
post Dec 30 2011, 07:28 PM
I did have it raised to the one of the trans mounts and almost at the other. The front was making contact. I had the front bolt in, it just wasn't threading.
rgalla do you remember if your bolt tapered? Thanks guys maybe it was just off a little?
carr914
post Dec 31 2011, 06:34 AM
Racer from Birth
I remember when I was putting Steve Gagliones' motor back in his GT. We were doing on his Garage Floor with the car jacked up. Of course the car was an angle to the floor which caused things not to line up. I got the Tranny Mount Bolts in and Steve was putting the Engine Bolt in. He was turning it for ever. I looked at it and the bolt wasn't far enough up. I grabbed a hammer and he freaked (Funny if you know Steve and his car). I just tapped the end of the bolt a few times to move it up a little, then threaded it in like butter.
rgalla9146
post Dec 31 2011, 09:25 AM
QUOTE(carr914 @ Dec 31 2011, 04:34 AM) *
Hey Tom, 4:31 AM Wow !
I would gladly look at my front bolts today to see if they are tapered but they are holding engines up
The angle of the car and engine leads to difficulty.
If you are trying to slide the engine forward onto correctly installed (with the bolts hanging out of the rear mounts ) trans bolts that makes it tough.
I've turned the bolts over to simplify installation.
When you have the eng/trans well balanced, lift it into position and apply some force to hold it against the mounts. Just enough so that you can still move it with a drift pin, big hefty punch or even a big phillips screwdriver.
With a 914 it can be a bit tight and un-nerving to have to go under a un-attached
engine and start pushing and pulling.
Get the two rears started first. Not tight.
Then get a view up into the front mount and align the parts.
Toms idea to tap the front bolt up through the mount is good.
Then, as you turn you should feel it thread.
Krieger
post Dec 31 2011, 10:58 AM
I must have been so dang close, plus I was a virgin so it was awkward, but I got it in. (IMG:style_emoticons/default/biggrin.gif) Next time It will be like butter.
Chris Pincetich
post Dec 31 2011, 02:00 PM
B-)
Great way to end the year! (IMG:style_emoticons/default/beerchug.gif)
ConeDodger
post Dec 31 2011, 02:48 PM
Apex killer!
I don't need to know Steve to know that if it was my car, I would remove all the hammers from the garage. (IMG:style_emoticons/default/blink.gif) That'll probably be a quarter million dollar car someday... History, rarity and all... (IMG:style_emoticons/default/biggrin.gif)
carr914
post Dec 31 2011, 04:48 PM
Racer from Birth
QUOTE(ConeDodger @ Dec 31 2011, 03:48 PM) *
Yeah but it was funny. Not as funny as the The Shredded Chicken that his wife left us. Steve turned on the Stove and put it on a burner while we were working. It was black in the Pan when we got finished. Steve wanted to throw the Pan away, but he knew Janie would kill him for that too. She called me the next day and apologized for Steve not buying a Pizza or something.
Krieger
post Dec 31 2011, 06:43 PM
The front bolt is the original tapered one! I guess I was not going in straight. Next time.
- Lo-Fi Version Time is now: 31st July 2025 - 08:04 PM
