Exhaust Set up, What do I get from this change |
aharder |
Jan 7 2012, 09:03 PM
Advanced Member Group: Members Posts: 4,405 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
My stock 1.8 exhaust drops down and heads toward the front of the engine and connects to the exhaust pipe and does a 180 towards the back of the car and connects to a Bursch Exhaust .
Do I get any of benefit if I change it to where the exhaust pipe drops down and heads towards the rear of the car and connect to a pipe that connects to the Bursch? |
ClayPerrine |
Jan 7 2012, 09:11 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That was done to accommodate the emissions requirements. Take that stuff off the car, and float test it. Replace it with a nice set of early 2.0 Heat Exchangers and a Bursch 2.0L muffler. You you will gain both horsepower and heat.
aharder |
Jan 7 2012, 09:34 PM
All of the emissions stuff has been gone for years (IMG:style_emoticons/default/biggrin.gif) As you can see, no heat exchangers on the pipes. I'm in Texas and I don't need any Heat (IMG:style_emoticons/default/biggrin.gif)
I'm thinking this set up allows more room to the valves. |
euro911 |
Jan 7 2012, 09:40 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I had thought of doing the same thing with the 75/76 exhaust manifolds, but decided to go with a set of early 2.0L manifolds with heat exchangers.
Since I'm getting older (and lost a lot of weight) I find that I don't like cold temperatures as much as I used to. Heat in the car is a wonderful thing, vs. optimum performance. EDIT: Finally found one of my old posts (on NARP) from early 2009: "Bruce Stone provided me with a set at the 'So Cal All Porsche Swap Meet' last Sunday (Thanks Bruce) (IMG:style_emoticons/default/beerchug.gif) ... I've since blasted and painted them w/1200 deg paint (more to keep them from rusting than anything else) until I start modifying them. The experiment will entail cutting off the 3-hole flanges, repositioning the exhaust port stud U-tabs if needed, mount the manifolds pointing backwards, extending the pipes back, welding on 2-hole flanges and mating up to a Triad 6-cylinder muffler system. The engine will be either a stock 2.0L or a 2056 ... " Attached image(s) |
raw1298 |
Jan 7 2012, 09:42 PM
Senior Member Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California |
I am doing the same thing except with a boxster muffler. You will have to mount to opposite head to get them to bolt up when you turn them around.
jimkelly |
Jan 8 2012, 06:54 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
the drawback to this system is the the TOTAL I.D. is quite less than with earlier systems. i have a set of 2.0 steel without tin in the classifieds. see pics
Attached image(s) |
ClayPerrine |
Jan 8 2012, 07:05 AM
All of the emissions stuff has been gone for years (IMG:style_emoticons/default/biggrin.gif) As you can see, no heat exchangers on the pipes. I'm in Texas and I don't need any Heat (IMG:style_emoticons/default/biggrin.gif) I'm thinking this set up allows more room to the valves. Ok..you are here in the DFW area. I don't have a muffler, but I have a set of stock 2.0 heat exchangers I will give you if you want them. That offer includes everything I can find to install the heater pieces too. I have LOTS of parts. Just come pick them up. And heat is nice when it gets cold here. My six has heat on it and I intend to keep it. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:16 PM |
